Question about Frigidaire FAH106R2T Thru-Wall/Window Air Conditioner
No cool air is coming out turn the air conditioner on, only warm air is coming out, no cool air
  • James Ely May 11, 2010
    Did this symptom occur gradually?
    Novelist:
  • 166 Answers
How long have you had the A/C? It might be the time for a good cleaning. There are a variety of factors that may cause your A/C to not cool your house. With that said, here is a diagnostic article that provides the most probable causes of your A/C's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Of course, a low level of Freon/refrigerant may be the problem, but there may be other problem causes as well, as noted in the article---it may just be that debris is obstructing your AC as well. Read the article, and, if need be, get another AC technician and take advantage of the text-ad link (found towards the middle of the web page after the article) for free four (4) quotes and "pick the brain"--seek the advice--of these technicians who offer you a free quote to discern what could be the problem.
Posted on Jul 18, 2009
My a/c works fine,I think, but every time the A/c comes back on it cools a little more dropping the temp each time it comes back on.
Sounds like your air-conditioner is near a source of heat... So it cools the room, including the area near itself, but then the area near it gets warmed up faster than the rest of the room... Causing it to go back on again.
Remember an air-conditioner temperature sensor is located right in the front of the air-conditioner... So if the area around the air conditioner is near a heat source (or a vent to outside warm weather) then it's going to keep turning on and making the room colder and colder each time.
May 24, 2016 | Winnebago 2007 Aspect 26a
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
I bought a DeLonghi PACC120E portable a/c with no manual. The unit does not cool, and it dumps water. How do I get it to blow cool air?
I would drain the water out of the machine via the plug on the back once the unit is drained turn on, wait a few minutes. If compressor does not come on or comes on and does not cool, you need service beyond diy.
Jun 18, 2014 | DeLonghi PAC C120 Portable Air Conditioner
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
Cool air comes out when the heat turns on. When I switch to Em heat, warm air comes out. Over the summer the air worker great, however when I switched to heat on the thermostat, cool air came out. Why?
Check the following. 1. Your setting temp must be higher +3 than room temp. 2. Check heating sensor.3. And also heater element.(If it's reversal valve, checke RV is working)
Dec 12, 2010 | Weather King 10AJA3601AH Air Conditioner
Not Cold Does not cool warm air comes out of it
The compressor is locked up and making heat..
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 06, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Heater smell when AC comes on...
The fan that blows the air blows through the heater coils before it blows through the A/C.As long as the heater doesn't come on, there is not much that can be done. ZCooking the attic room will be a problem because it is the heat rises thing, and on top(literally) of it all, the roof is radiating heat.
Sep 21, 2009 | LG Heat cool Window Air Conditioner
Air conditioner symbol defrost keeps coming up so much trhat air conditioner is not warming room let alone blowing warm air. Spend all its time defrosting than warming the room
These will defrost themselves automatically when they need to - internal sensors. If it is icing up at all in cooling, then the charge is wrong. Units such as this are very sensitive to incorrect charge, so I would recommend that you have a qualified tech come out, recover all the freon and weigh in the correct charge. If this is a "new" problem, then a leak check/locate would be in order.
Aug 30, 2009 | LG Art Cool LA091HNP Split System Air...
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Jun 30, 2008 | Frigidaire FAH08EJ1 Air Conditioner
Frigidaire FAH106R2T Thru-Wall/Window Air Conditioner Logo
106 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
