Question about Pentair Minimax NT Heater
Replaced ignition module, e04 error code, now flashes once
We just replaced the ignition module and are getting an e04 error code which is airflow. Also there is one flash on the new ignition module which indicates fan failure. Also on the inner side of the digital display the tfuse light is lit up. Any help would be grealy appreciated
  • 2 more comments
  • zinnel Jul 18, 2009
    We are questioning the fan. It doesn't want to start on its own, but when helped, it runs. Could this still be the issue? Thank you.
    We are questioning the fan motor also. It doesn't seem to want to start on its own, but when assisted, it takes right off. Could this still be a cause? Thank you.
    The
    The fan doesn't want to start on its own, but when assisted it takes right off, could this still be an issue? Thank you.
  • 3,037 Answers
Sounds like the fan motor may have finally died. Have you noticed the fan not running or running poorly on it? Motors eventually die and since it's not working anymore, the power going to it is setting off the code and the light you mentioned. Let me know how this turns out.
Benjamin
Posted on Jul 18, 2009
  • Benjamin Patri
    Benjamin Patri Jul 18, 2009
    Yeah, the fan motor is bad and should be replaced or its not getting enough voltage, most likely bad. You could try cleaning the whole unit first and seeing if that helps but if not, then replace the motor.
I have a 2000 Mercedes SL500. Cluster is flashing 'start error' and I have a P1570 code. Engine cranks but won't start. Starter has an abbreviated spin time too
code p1570 refers to ignition switch control module/ECM-attempted theft/data bus/not compatible ===causes --wiring--connections--trouble codes stored in other system--ignition switch control module---ECM
If this is a recent problem I would suggest that the ignition switch module be checked/replaced.
Nov 03, 2014 | Mercedes-Benz Mercedes Sl 500 Class Sl500...
E04 minimax error code
check to see if you have adequate gas pressure sounds like it running out of gas pressure
Aug 04, 2014 | Pentair Minimax NT Heater
Since you said you replaced the fan, and flow valve. Did you re-install the pressure switch correctly? it will look something like attached image. This is more than likely the cause if you did not replace with the fan or reinstall correctly... or it might have been the cause in the first place...
Gas furnace with Honeywell smart valve code error 6:2, replaced the following: pressure switch, smart valve, ignitor flame sensor and control board. Cleaned out the condensate line. Still getting 6:2 flash...
Hello, it sounds like your Furnace might be shutting off due to your high limit switch.A limit switch will open when the furnace overheats due to low airflow, . check air filter, clean blower wheel, and check to make sure the blower wheel is running at proper speed and not dragging sometimes cause by a weak capacitor. Anything that restricts airflow will cause a limit switch to open.
Mar 08, 2011 | Honeywell Heating & Cooling
96 pontiac grand prix se 3.1 service engine light is on and flashing. car runs bad. sometimes it has no power to get up an go. goes through alot of gas and smells of fuel bad. had it put on computer all...
clear the codes run engine and see what codes come back up egr valve that could just need a clean, ignition coil and module that could be just because of the egr valve, misfiring could be the spark plug or lead on number 3, check clean all spark plugs, check clean or replace the air filter and check for vacume leaks.
Jul 29, 2017 | Pontiac Grand Prix Cars & Trucks
Kenmore model 417-44052400 front load washer error code E04 (5 vertical LED flashes & beeps and 4 start led flashes. I ran the diagnostic test, it dose everything up to tumble, it won't tumble or...
Take the front lower panel off 2 or 3 screws you will see the pump.You will see a black "baffle" atatched to the pump.squeeze it feel a sock?Take the boot loose and clear.Only other thing would be the motor control board back let hand corner replaced many of these when tubs dont move.I hope this helped.
Nov 17, 2009 | Crock Pots & Slow Cookers
Module replaced, 2 uses later ignitor burned out, replaced ignitor, module burned out ...to the tune of 400.00, 3 service calls and are now looking at 200.00 more...now what?
If I understand your situation, you have already replaced the Module once, then the Igniter went out, so you replaced that, and now the Module is not working again. If this is correct, I would call the servicer and have them come out and see what they did wrong, Modules do not go bad in just a couple of uses.
I am not sure if you have any error codes, or know about the diagnostic lights on the back of the Digital Display panel, but I would first try and reset the heater. To do this you will need to turn OFF the heater by opening the right hand side door and turning the POWER toggle switch to OFF. Then find the circuit breaker that goes with the heater and flip that off. Wait between 15 and 20 minutes, then reverse the order. Circuit breaker on, heater on, then try and start the heater.
Watch for any error codes, like EO5, the heaters computer will flash a series of start up "codes" like 888, do not worry about those. If the display comes up, check the water temp that it is reading compared to what the water temp is actually. If different, the problem could be the Thermister and not the Module.
Jul 06, 2009 | Pentair Minimax NT Heater
Error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Jul 27, 2008 | Washing Machines
E04-14 error code
If your standing facing the back of the machine, you will need to change the top right fan that cools the IH,power supp. there are two fans which need to be replaced, the other fan is behind the sc pcb but that will give a different error.
Feb 15, 2008 | Panasonic DP-C354 Copier
Pentair Minimax NT Heater Logo
305 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
