Question about Milwaukee Tool Milwaukee Orbital Jig Saw with L.E.D. 6268 - 21
After inserting a blade in the quick lok, the blade does not line up straight with the guide. The blade goes beyond center.
  • 32 Answers
The blade lines upaccording to the rotor shaft and has nothing with the guide except for the fact that the table has been droped and bent out of place or has been tweeked out of place somehow, usually hitting the floor from the table top causes this. Loosen the table screw to see if you can get it back in place and square it back up, hope this helps, good luck!
Posted on Jul 18, 2009
Attach edge guide onto skill jigsaw
I don't know why they even provide edge guides with jig saws, they don't work worth a flip. The problem is that, unlike a circular saw, the direction of cut is unlikely to be 90 degrees from the direction of the mounted edge guide. The blade mounting is not made to ensure that the blade is held exactly straight. When you follow a straight line with your cut you will see that the body of the saw will probably crab a bit sideways like a car that badly needs a wheel alignment. I suppose the edge guide can work on 1/4 inch plywood with an aggressive blade, but that will give you a very rough cut. Much better to draw the line and just follow it visually. If you need to do a lot of this, and you want a nice straight line, use a circular saw. Good luck.
Jan 15, 2013 | Craftsman 680915001 Edge Guide
Milwaulkee sawzall quick release wont release.Cam turns ok but pin is holding blade.Tried prying blade out w/vise grips-no luck
try using WD-40 first to loosen up pin and if not you might have to replace the quick lock assembly. ot a tough job about 10 minutes or less.
Jan 17, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
My dad's old craftman table saw will not cut straight. I put a new carbide tipped blade in to try to solve the problem with no luck. the wood is cut narrower in the center and it won't stay tight against...
Your problem could be one or more of... 1- Check to see that the motor mounts are secure and the motor is not moving around. 2- Check the shaft that holds the blade for the same problem if the blade is not directly mounted to the motor. If there is any "give" in the above two ways the blade could be held in place, corrections must be made to secure the blade so that it does not "wander" during the cutting procedure. 3- Be sure the fence you are using to guide your wood is set as parallel as possible to the blade so it does not cause the wood to follow another line once the wood being cut goes beyond the cutting blade. There is most likely an alignment procedure you can run through.
Sep 14, 2010 | Garden
My blades are not cutting straight. I have tried new blades,many adjustments and different tensions to no avail. Could it be the bearing behind the blade? Help!
Believe it or not, your little saw will cut a pencil line in half.Take the guides and the bearings out of the way of the blade, turn it by hand till the blade rides in the center of the tire. Make sure it isn't touching any guides. Then tighten up the blade till it twangs. Then bring in the bearings and the guides, just ouch the bearings, do not push the blade at all. The guides should be just behind the teeth and almost touching the blade. This should work perfectly. If it doesn't, then you have something wrong, like a bearing gone out on one of the wheels, or the guide bearings have notches in them. Or the guides are not close enough. You can make guides out of anything, wood, plastic, brass, dowels, anything to guide the blade and stop it from twisting. Remember the blade doesn't move, the work does. Hope this helps.
Apr 20, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Blade stays in a bind. coming thru the table it is not straight coimg down, it is set to zero on the tilt gauge, which puts the blade hitting the little angled guides above and below the table
Back off all the adjustment to the guide bearings and the guides. Get the blade to track, and stay in the center of the tires,(wheels), tighten up the pulley, then set the top bearing to the blade, just touch it, then the bottom, turning the blade by hand, then bring in the guides just to the back of the teeth. The guides should be close to the blade but not touching it.You should be all set, If the blade won't track by itself, you have an alignment problem with the two wheels, if it is a 3 wheeler, then one of them is off. Check them with a straight edge against each other,if you can, one will be tilted. It might need a new bearing it self.
Feb 15, 2010 | Craftsman 3/8 x 80" Band Saw Blade, 6 tpi
Not cutting in straight line
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Sep 25, 2009 | Saws
Sawzall goes dead when horizontal top right
could be a break in the cord or a loose terminal at the brush holder. If you are mechanically inclined get back with me and I will instruct how to find. You will need the exact model number. If this is a quick lock cord as listed unplug and look at the terminals to make sure one not pushed away from tool and condition of the plug in handles. Let me know
Sep 06, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
When making a straight cut with my bandsaw, the blade will
Before tuning it up, loosen the guides and wheels away and square the table to the tensioned blade. Then follow these steps in order:
  1. First, adjust the upper wheel so the blade is tracking at the center or just to the front of center of the wheel tire. (You can see this with the cover removed, and adjust it with the nut/wing nut in the back).
  2. Now, make sure the blade guides are adjusted so they don't deflect the blade to either side (when looked at from the front), so they contact the blade just behind the gullet of the teeth, but not against the hooked teeth themselves, and are just tight enough to allow the blade to run freely (including the weld). (If your guides are worn and out of flat, you may wish to dress them on a sander before adjusting them against the blade.) Adjust the guides both above and below the table. At this point, ensure that the guide bar moves up and down easily and locks into position without torqueing the guides against the blade.
  3. Finally, adjust the bearings behind the blade, so they just kiss it, and turn freely when you revolve the bandsaw wheel. They will support the back of the blade when pressure is applied against it during a cut, and help immensely to keep the blade tracking straight.
At this point, check the cut by trying to follow a straght line penciled on a board. Some blades will naturally tend to veer slightly on a diagonal, depending on how they are sharpened, and you may have to adjust your fence to compensate for this "drift".
But if you follow the steps outlined above, and have a good sharp blade to begin with, you should be able to split a line.
If you follow these tips and they prove helpful, please let us know your problem is solved. Otherwise, give us a little more detail and someone will be happy to follow up.
Mar 20, 2009 | Delta Saws
Milwaukee Tool Milwaukee Orbital Jig Saw with L.E.D. 6268 - 21 Logo
244 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
