Question about GoVideo VR4940 DVD Player/VCR
It locked up while recording from VHS to DVD recorder. Unpluged unit and VHS will work but not the DVD player at all.
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
  • 4 Answers
SOURCE: go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
Posted on Sep 26, 2008
Jannarama
  • 14 Answers
SOURCE: My go video is locked. How do i unlock it?
The LOCK/UNLOCK feature is for the DVD+RW type discs. You cannot unlock a DVD+R once it's finalized.
For a DVD+RW,
  1. Place the disc into the machine
  2. Use the UP arrow to go to the top menu.
  3. Press the RIGHT arrow to display the disc information menu
  4. Use the RIGHT/LEFT arrows to select "LOCK/UNLOCK Disc" option.
  5. Press ENTER
  6. Change the disc status
  7. Press ENTER
  8. A "Changing Disc Status" bar appears. Process can take a few seconds.
  9. Menu disappears when process is complete.
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: my remote for my sv2000 dvd recorder model#wv10d6 won't work
If your absolutly sure the remote doesnt work there is a power button on the unit its self. As far as a universal remote goes, I my self would like to know that. After much research I have found no info on another remote working
Posted on Jan 07, 2010
Batstar
  • 122 Answers
SOURCE: Unit does not recognize DVD-R and is ejected from the player
You may need to try a DVD+R disc. Some of the players/recorders are REALLY picky.
Posted on May 17, 2010
How to record dvd from vhs
There are some units that can do this, but if you are trying to copy commercially recorded VHS movies to DVD you will have issues. The VHS tapes have copy protection on them and all manufactured hardware to record these have been required by law to support the protection. Thus, you will get poor copy reproduction when copying. If they are home-movie style VHS tapes, no such issues exist. You can either get a unit that has both devices integrated and has copy capability, or you can you a VHS player and send the outputs to a DVD recorder.
Jul 09, 2016 | Televison & Video
My dad just purchased a 2004 memorex t.v. with built in dvd and vhs players. He wants to know if he could record a vhs to a dvd on t.v.
No,the DVD player build in tv can't record,only play DVD Disc only.Want to record personal VHS tapes only to DVD Discs,must have a seperate device unit VCR/DVD RECORDER device player not a device unit VCR/DVD PLAYER.Connected to the tv record VHS tapes to DVD Discs.
Mar 14, 2011 | Memorex Televison & Video
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
CAN I RECORD A MOVIE FROM VHS TO DVD?
Not if you mean recording within that 1 unit from VHS to DVD.You would need a second unit DVD recorder which normally requires a digital input of some sort such as a cable box or a self-contained digital scanner but I am not sure if that would even work.It would depend on what the media input was recorded on the VHS.
Sep 25, 2010 | Sanyo DVW-6000 DVD Player/VCR
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
DVD player will not read any discs.
> I tried recording a VHS to a DVD according to the instructions in the manual.
There can hardly be instructions in the manual to do this since that model is not a DV Recorder, but if it isn't reading any DVD then you have a warranty problem assuming your unit is still within the warranty period.
That unit is capable of recording DVD content to VHS tape but not the opposite.
Mar 13, 2010 | GoVideo DV2130 DVD Player/VCR
Can i record a video from a vhs tape to dvd using my zenith? what disc should i use?
no you can record dvd to vhs but not the other way around as the dvd unit is a player but not a recorder
Nov 22, 2009 | Zenith XBV442 DVD Player/VCR
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Dec 26, 2008 | Philips Magnavox DVD/VCR Dual Player
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
GoVideo VR4940 DVD Player/VCR Logo
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
