No sound at all! Headphone jack doesn't work either. I noticed the sound "card" is like a drop in module with pressure contacts to the motherboard.
  • 3,866 Answers
Yes and this can be removed and replaced with a new sound card. you can take that old one out while the computer is off and have it tested by any technition to find out what the issue is it probably needs to be replaced. I hope this helps
Posted on Jul 18, 2009
Zoostorm netbook mouse buttons
check to see if front pannel wiring board has the jack well placed there and all wiring is ok, if all ok you could try with contact spray within the jack itself, last option is to check if wires from front pannel to motherboard are placed where they should be, respecting the proper way of placement (+,-) , if that doesnt work, try installing your sound card again and it's application, in the application itself you should have a option : Pop-up when jack input detected. hope that helped you.
Mar 02, 2014 | Intel Computers & Internet
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
Remove broken headphone jack on an Optiplex 745
Since the Headphone jack is soldered onto the motherboard in most cases you could remove it by unsodering it from the MB. However, replacing it might cause another issue. You can always install a sound card that would allow you to have additional headphone jacks.
Jan 17, 2013 | Dell OPTIPLEX 745 PC Desktop
It could be there is dust in your jack. Cut down a Q-Tip and stick it in. If that doesn't fix it, it could possible be the jack has gone out. There are USB sound cards that would provide a jack.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812705175&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Other+Adapters+%26+Gender+Changers-_-N82E16812705175&gclid=COqQ9aX977QCFXCmPAodogYAUw
Jan 17, 2013 | Computers & Internet
My gigabyte g41 combo doesn't detect front port jack . So i'm having problem in using headphones from when i bought this mother board.I tried both XP & 7 .My front port sounds only when i...
1. check if your front panel is connected to your motherboard at proper port2. check "expert mode" on your via hd audio deck, click "advanced options" and check "redirected headphone" (THIS WILL UNCHECK "INDEPENDENT HEADPHONE") and uncheck "enable front panel jack detection"
this should solve your problem.
Sep 22, 2011 | Gigabyte GA-G41M-Combo Motherboard
Front headphone jack does not work, do not get sound. I have an a1450n HP Pavilion running windows 7 ultimate. Running Realtek High Definition audio drivers. This problem is quite common on the internet....
If you face issue with only front jack then you need to check the connection of front jack to motherboard. For that open cpu cabinet cover.Then find the cable from front sound jack to motherboard. Connect it into right position .You can find diagram on motherboard or in manual.There is some pins on the corner of motherboard. Let me know if you need further assistance. Thanks for using FixYa.
Feb 28, 2011 | HP Pavilion a1450n PC Desktop
My headphone jack is not working at all. I just purchased it today, the sound card is saying no errors, the sound plays fine out of the speakers and the headphone do work Im using them on my cell now
Take it to the Service center. need to replace the headphone output connector's. these will happen from Moistor,Dirt block or Dry solder in the Laptop Motherboard. best of luck. ( Try, put headphone jack in and out for 20 to 30 times, or check the sound comes out via headphone, when pressing the connected jack.) best of luck
Feb 01, 2011 | Sony VAIO VPCEA36FM/W Laptop
No sound on monitor speakers
You have installed a new sound card however you won't be able to use the monitor speakers unless there is a seperate cable that you can plug into the headphone jack. Or you can get some speakers and plug them into the headphone jack.
May 29, 2009 | Aureal 2 Channel PCI Sound Card
My ipod 30gb 5.5gen wont produce sound on the headphones and i already replace the audiojack and still the same problem please i need help, plus on the diagnostic mode wont show the audio test under the IO...
the diagnostic mode won't check the audio, only the headphone jack.
I suspect that the sound on your ipods motherboard went out. It happens!
Have you been using the ipod on a dock, a speaker dock, any dock?
If so the dock may have damaged the motherboard and too the sound out.
Or the sound on the board just went out. You can fix the boards without special equipment and
skill. If that has occurred, which if you replaced the headphone jack with a new one, has occurred
you are looking at replacing the motherboard in your ipod.
You can find a new motherboard on ebay for about 40.00 or so.
Good Luck
Apr 18, 2009 | Apple iPod Photo MP3 Player
Broken headphone jack
you should be able to get it out from the inside on the card. Do you have a sound card or is your sound on the motherboard?
Jan 27, 2009 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
