Question about Kenmore Ovens
Display shows F 7 ??? - Kenmore Ovens
    President:
  • 1,197 Answers
Assuming that ur brand is a kenmore oven.....
I'm afraid F7 on that make of range usually indicates a problem in the control keypad in which case on your model the whole console panel usually needs to be replaced to correct the condition.
LINK > Kenmore 911.47469690 Control Panel, Black
LINK > Kenmore 911.47469690 Control Panel, White
LINK > Kenmore 911.47469690 Control Panel, Almond
have a nice day
thankyou for using Fixya
Posted on Jul 18, 2009
Samsung range with digital display not working properly. Clock shows half of the numbers.
Replace the display board. There will be a segment driver that has failed.
May 06, 2017 | Samsung Ovens
The digital display does not work i think the bulb has gone do you know how i can fix it easily?
"digital display's" do not use one bulb for illumination, usually a 7 segment LCD display is used. The entire display will have to be replaced, IF the display is at fault.
Jun 17, 2015 | Ovens
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
My oven will not operate after self cleaning show nothing on display
This is your display control board that has gone out on you. This is a fairly simple repair and you can save a lot of money by making the repair yourself. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST Monday through Saturday and we can get the correct part out to you asap. When you get your parts from us, we also send part removal/installation instructions to our customers.
We look forward to working with you and we wish you a Happy Thanksgiving!
Thanks, Ella
Nov 25, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven temp lower than display shows maytag gas w/electronic controls 30 degress lower than display shows ignitor changed 7 days ago
I would say that the igniter isn't faulty, this is an oven thermostat fault, replace the stat, and should be resolved.
I hope this helps.
Jul 07, 2009 | Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Clock
What country are you in. This model does not show up in Kenmore USA
Perhaps you gave me the serial number by mistake, rather than the model number?
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
177 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
