Central air running all day and not cooling properly...
About a month ago I had to take apart the out side unit fan and clean it, it got stuck, its working now. a week after i started hearing a noise every time the blower shut off, like the vents scratching the corners. We got it out and some how the vents got loose on the shaft and was cousing free wheel motion. also cleaned the outside coil, cheked freon (ok), air pressure, (ok). now the noise is gone but it still not cooling the house properly. there is no ice... although its summer and temperture during the day out side its over 91° to 100° the system its usually stopping around 4:am and it comes back up around 10am.
Any ideas?
  • 1 more comment
  • ejflores07 Jul 18, 2009
    the capacitor is good, and the fan position problem fixed. but wht you say about the compressor make sense or the condenser. the blower blades has been creating resistance for a few weeks and tht might made other components in the unit to over work... the air sometimes feels like a lil moist... I think im gonna keep the unit off part of the day... dont want to hurt my wallet when the electric bill comes.
    Thanks!
    the inside unit in the attic (lennox cb-30m).
    yes I meant to say the blower wheel.
    the freon and the pressures i got a friend help me w tht, so i dont know what kind. the suction pressure was around 70.
  • 420heff May 11, 2010
    what kind of unit is it what is vents on shaft ?do u mean blower wheel?what kind of freon what are the pressures suction and discharge
  • 614 Answers
Did you fix the problem with the fan. Some times the placement of the fan blade up or down influences he air flow. May not be moving enough air across the coil. Sounds like it is over heating the compressor. To much amperage. You also may be losing conductivity of the condensor. When they get ols the fins go bad and loose conductivity. Also check capacitor it may be weak and causing compressor to pull to much amps. The capacitor starts the unit and also lowers the running amps by pulling the start windings in phase with the run winding. Russ
Posted on Jul 18, 2009
M6X08F2A Air Conditioner problems not blowing cold, not cooling off apartment
Sounds like the heater is on as well. Even if ac is not working it shouldn't get hotter than outside air temp. Possible stuck relay.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 01, 2017 | Maytag Heating & Cooling
Central air conditoner outside unit
Well, the answer is yes. I have seen a bad capacitor cause a fan motor to run backwards. BUT..... After replacing the capacitor and WIRING it up the right way, everything should be fine. A lot of aftermarket condenser fan motors are reversible, so it can run counter-clockwise (CCW) or clock-wise (CW). However, most factory fan motors come one directional and on your specific unit, the air should always push out of the top. Running the unit with the fan going backwards will actually some-what do it's job, but damage other components like the compressor because it runs at higher operating pressures than what it is designed for.
Have someone else look at it! That's going to be the best advice I can give you. If they can prove that a capacitor caused the motor to permanently run backwards..... I want to know! Hope this helps and good luck with your unit.
Jun 22, 2012 | Heating & Cooling
It is 105-110F outside and I think that I am only getting no more than 2 degrees of cooling from my central air conditioning unit. I have been changing my air filter about every two days, two months ago...
Two thoughts come immediately to mind. Your outdoor condensing unit may not be running at all or is extremely low on refrigerant due to a leak or you have flexible
ductwork and it has come apart under your home especially in the return area.
Also, if you feel the larger of the two lines to the outdoor unit and it is not "Beer can cold" then the compressor is most likely not running, just the fan which would give the appearance the unit is running.
This would most likely be a failed capacitor. (secure all power from
all sources to inside and outside unit and pull out the disconnect before attempting
replacement). Check for bulged cans or leaking cans and replace with exact same
microfarad/ voltage rating. You can get the caps from any HVAC store for around 20 dollars.
Aug 07, 2011 | Heating & Cooling
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Window A/c 10 or 15 days is good working\r\nbefore !0 or 15 days ago all Eveporater and section line freeze fan moter good praper work melt the freeze and A/C on A/C giving good cooling what is problem
Hello
You may try cleaning the evaporator filter,Also cleaning the outside coil or condensor,Simple green works good for cleaning coils and a garden hose.
Also cleaning the evaporator may help.
When unit is running properly the evaporator should feel cool and wet from top to bottom.
Last,the unit could be low on freon.
Jun 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
No cool air but only fan working in central air condition
Check to see if outside unit is running. If it is check breaker,float switch inside. If everything is ok You have to call a Service Tech. There is only so far you can go. If you think the gas company had anything to do with it call them back and tell them it was working before you checked the gas. They could have left something off. Russ
Jul 23, 2009 | Heating & Cooling
Fan in our Sharp "Comfort Touch thru-wall a/c stopped
Unless the Unit can be cleaned ( you claim it cools?) but not enough. The age of the Unit is not in you Question, the amount of time you got for 100 bucks is pretty good being you purchased a USED UNIT. With the type of use you claim Running 24/7 and about 5 months of cooling - I'd say you never cleaned the Unit from day one - that might cost you about 100 bucks if the unit can be done in the yard by a serviceman. Chemicals can hurt the Unit if not done properly ( and yourself). It sounds to me like you use it for a Business - if so you can purchase one and write it off .
Jul 18, 2009 | Sharp AFR120NX Thru-Wall/Window Air...
Central air conditioner doesn't cool
no cooling means outside unit is not operating due to
-no thermostat signal
- condenser dirty need cleaning
- fan motor stucked 90% this the reason of noize
Apr 27, 2009 | Heating & Cooling
Heating & Cooling Logo
249 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
