Question about Indesit W 123 Front Load Washer
Washing machine won't drain
I can turn my washing machine on the cycle to start and will do every thing until its time to drain the water it won't drain. Help me please
  • Indesit Master
  • 3,463 Answers
Sounds like the pump is not working, or the filter is blocked.
If there is a removable bottom front panel of washer, remove this and the filter should be located behind it. Remove and clean.
Please rate my solution.
Thanks.
Posted on Jul 18, 2009
appldoctom
  • 311 Answers
SOURCE: my washing machine wont drain water
if waser wont drain it cant spin and some contorl boards get confused about that situation.check your pump,is it clear will it funktion.other wise i dont know a lot about this proticular machine god bless,tom
Posted on Jan 01, 2009
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
dr appliance
  • 266 Answers
SOURCE: washing machine won,t drain the
something stuck in pump
Posted on Jan 27, 2011
  • 6 Answers
SOURCE: won,t drain on rinse cycle
I had this same problem. I replaced the computer and the relay boards without luck. I found it was the FILL VALVES! Apparently when the washer changes cycles it expects water to fill the tub to a certain level. If the valves are not opening and water not filling the tub will cause the computer to just wait and wait and wait and wont advance to the next cycle.
Posted on Dec 19, 2011
Machine won't start the wash cycle
All bosch appliances are sold with a two year manufacturers guarantee. Call 0844 872 8999 to arrange an engineer. Sounds like it could be any of the following Heater, PCB, Pressure switch or Motor fault
Mar 24, 2013 | Bosch Washing Machines
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
Asko 620 washer won't drain well with heavy load
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Indesit W 123 Front Load Washer Logo
271 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
