Question about Bakers Pride Ovens
I'm ready to purchase a y452 that seems to have a good amount of rust inside. will this rust reduce wit the high heat or will it get worst over time and turn into a rust bucket?
  • 1 more comment
  • jettingtothe Jul 18, 2009
    i'm ready to purchase a bakers pride y452 gas oven that has rust inside the upper deck and a little inside where it produces fire. will this oven eventually turn to a rust bucket. or will the heat while on reduce or eliminate the rust?
    i'm ready to purchase a y452 bakers pride gas pizza oven that has rust inside the upper deck. it's fully operational. will the rust get worst over time or should it be ok?
    i'm about to purchase apair of y452 bakers pride gas pizza oven that has rust inside the upper deck; will the rust continue? or should it stop being that the oven was sitting for a while but will be running all the time when i get it?
  • 3,037 Answers
Pizza has moisture in it and it is released into the air when baking. Moisture accumulates and if it isn't consistently wiped from the surface, then that surface will rust. The surface could be refurbished but it usually doesn't do that much good to bother, since the rust tends to come back and will get worse. I guess if you want to buy it, it would have to depend on how much you are paying and how long you intend for it to last whether you get it or not. Let me know how this turns out.
Benjamin
Posted on Jul 18, 2009
  • Benjamin Patri
    Benjamin Patri Jul 18, 2009
    It will run fine, but it will continue to rust over time. Depending on the amount of rust, it should last a few years at the very least
  • 520 Answers
If the rusted areas are not directly contacted by the flame then they can be treated and last another few years. However if the rust will come in contact with, or be near the flame then the rust will be intensified and sped up. High temperatures increase the rate of rust and corrosion. Where it may take it two or three years to rust through, with excess heat and flame the process may only take about six to eight months. If you are serious about these cookers then keep in mind that there will be additional repairs over and above normal due directly to there rust and water damage. Hope this helps. Please re-post with updates or questions. If you feel that this solution has helped then please accept and rate. Thanks cj2176.
    President:
  • 1,124 Answers
Heat does not make the rust go away..
I would advise purchaing a stove that has rust inside of it..
The rust could very well get worse over time..
Have a good day ;o)
  • Carl
    Carl Jul 18, 2009
    Rust will continue to decay the metal..
    What more can I say ?
    The question has been answered..
    Please rate well ;o)
  • 336 Answers
As long as the appliance is still functioning you are fine. Just make sure to remove the rust, apply organic rust remover (there's a lot currently in the market) if necessary. If not, it will eat up your metal and eventually affect your insulation which will translate to loss of temperature/heat.
I hope thi helps.
Kind regards.
  • jessy Jul 18, 2009
    No, heat while oven id ON would not melt or remove the rust.
    You have to remove rust first before using it. Here is an easy and economical way..
    first remove as much rust as you can by scrubbing with steel wool(no soap) ,use baking soda and salt ,clean as much as possible,rinse throughly .dry in the oven at about 250 for 20 min.then after cooling apply your usual cooking oil...back in the oven at 250 for 20 min more,then scrub with a plastic scrubber and clear water only ,dry...........now ,in the future,never use soap,only oil ,baking soda, and salt,always dry in the oven,never put away wet.
    Cheers!
    Hi, If the price is right, that would be a good buy. That oven is reliable. Just do a preventive maintenance with a little focus on rust before using it. Preventive maintenace will definitely eliminate the rust.
Why is the oven bell not ringing when it reaches the set temperature.
If the temperature reached at it operating temperature and oven display doesn't showing how much time left for ready screen then most probably its IO board gone.
I have seen many cases like this, and replacing IO Board fixed the problem.
Please rate my work
Thanks
Sagar
Sep 19, 2014 | TurboChef TORNADO Electric Oven
Turbo chef oven heats up too high and not ready
Bad SSR relay. Thermostat is for safety so it tripped first time, however since it's mechanical thermostat( not so accurate ) it didn't tripped on time for next time when it overheat
Jan 31, 2012 | TurboChef TORNADO Electric Oven
Can a large amount of water going inside your stovetop damage ruin it?
Yes it can, especially if it is not dried out immediately, It gets into the plates and insulation and will cause your earth leakage to trip out. With the stove unplugged or switched off, use a hair drier or heat gun to dry out all the water,especially the plates as water seeps into the internal insulation and causes a short. If there are signs of rust, clear this off with a fine wire brush (remember to keep the power switched off). If you can, after drying out the stove, check for current floe between earth and neutral and earth and live to make sure that there is no chance for a leakage there - use a multimeter set on the ohm scale or a Megger meter. There should be no continuity.
Apr 11, 2011 | Ovens
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The enamel on the bottom of my oven has started to flake can i buy paint to repair it before it goes rusty
You can buy enamel paint , depends where the rust is, you can buy heat proof paint if it is inside the oven.
If it is outside then treat it with a rust inhibitng paint first.
Nov 09, 2010 | Ovens
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
Takes forever & doesn't heat hot enough anymore-
most likely the element has gone bad and needs to be replaced element will cost average $40.00 plus a service call, to do it yourself you would need to unplug the socket and then work on the unit as the voltage is 220 so unless your handy at figureing out how to unscrew the parts apart and being able to take the part in I would suggest you call a tech to fix it. If I had a picture of the element I could tell you how to take it out but then there would be no warrenty if the guy comes out and fixes the problem he or she would warrenty the fixed problem for a certain amount of time.
May 29, 2009 | GE Profile JTP18 Electric Single Oven
Co smell during oven use
What you are smelling is the protective grease against rust or corrosion that came originally with your oven. the odor is normal if you are just purchase the oven.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven cleaning bosch oven
self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
Feb 10, 2008 | Ovens
Ovens Logo
73 people viewed this question
Top Bakers Pride Ovens Experts
ashburton
paulcarew
Dan Webster
Dan Webster
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
