SOURCE: Looking for hinges for a Dacor oven
http://www.repairclinic.com/SmartSearch/smartsearch.aspx they they have some here
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
SOURCE: I removed the oven door and took out the hinge to
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
SOURCE: Modern Maid Wall Oven DGO757 ignitor gets
I have a Modern Maid Wall Oven and the pilot light waant stay lit. What's the best solution?
SOURCE: How to unlock the hinge on an Ariston Oven Door wi...
To Unlock the hinge on an Ariston Oven Door Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you. With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over. Fitting the Oven Door Fit the door to the oven with the metal receivers in the slots on the oven. Once the receivers are in the slot, fully open the door (in a downward position). Flip the U shaped pieces over to lock the hinges.
