Question about Boating
Took out to the lake runs fine for awile but once you let of the gas and it dies wont crank back up put carb cleaner and they ran fine now wont crank up aqain
  • 86 Answers
Carb needs rebuild...idle jets clogged. That is why it will rum at high speed...the high speed jet is bigger and harder to clog. The idle jet is small and easy to clog. take apart and clean up jets.
Posted on Aug 02, 2009
Why does my 800 sxr jet ski engine runs full throttle and keeps running even after I pulled the spark plug caps?
dirty carbs !
reeds broken will spit back through the carbs !
crank seals worn can let engine run away !
Jul 07, 2014 | Boating
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Was using saw ran fine stopped and returned next day will not start fuel fine new plug filterers gas and air still wont start took to local chain saw repair shop they said that because it had water in gas...
check the carburetor. If you have a stiff diaphragm then it won't run.
I have seen them that behave just like that. They will run fine, turn it off for a few minutes then they won't restart. WD40 isn't going to get it to run either, try a small amount of mixed gas right into the carb. It should run for a minute until the gas you put in runs out then die. If it doesn't run then you have a bigger problem
Jan 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Hey i have a 94 tomos targa a35 and i put it together an now it will hit an try to run but it wont stay running even long enough to rev up it jus hits a lick then dies an i cant figure out the problem why...
you need to see if it is running out of gas try to crank with choke on an force it to run or see if it trys to run you can use a primer can with raw fuel and feed it from the back of carb when it stars an see if it stays running then if it does it is running out of gas may be float setting or petcock on fuel tank
Aug 01, 2010 | Tomos Se 125 F Motorcycles
Wont continue to run after prime and start
often the last ounce of gas in the tank has some crud in it. Get a can of carbeurator cleaner spray. Remove the air filter and squirt three short bursts of the cleaner spray into the air port and then start it. Keep giving it short bursts of carb. cleaner until it runs smoothly again.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Wont start now, idled last year but died when throttled up.
sounds like you blew some junk up into the carbs or injectors whatever the casse maybe. if you can try to blow some air through system or get a good cleaner and run it through the system, if its not too bad that should take care of it. These dont like running out of gas, try not to do so in the future. 1 more thing, sometimes a blast or two of ether will help also. Good luck
Jun 17, 2009 | Yamaha 12V Air Pump
06' V-star 650 wont idle...
Take the carbs back off and clean the jet completely,This is a carb issue and that is what you should focus on.
May 19, 2009 | 2006 Yamaha V Star Custom
I have a 150 hp outboard Mercury that is carburated. It has not been ran in more than a year. Boat had quit on the lake last April. Found bad starter. Had rebuilt. Put back on and was able to start in yard...
Did you put a fuel stabilizer in when you laid up the engine. If not varnish will build up in the system and clog the needle valves and jets. Use a good carb and injector cleaner to clear the jets.
May 14, 2009 | Boating
I have a craftsman 25 cc string trimmer with fuel problems. After winter, ran tank of good fuel through it and it worked fine. Added fuel (unknowingly with water in it) and it ran on a slow idle and...
You shouldn't notice a difference if you remove the air filter. So I would replace it. Also if you are using compressed air to clean or blow-out the carb. Be careful, its not recommended and could make it worse.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Boating Logo
76 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
