Question about Haier BC112G Wine Cooler
NEED FAN FOR MODEL HVTS18DABB - Haier BC112G Wine Cooler
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be affective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Posted on Aug 16, 2010
    Problem Solver:
  • 11 Answers
Go to any computer store liike Microcenter or ebay.
Search for 120mm fan and you should be able to get one.
the one on your wine cooler is the Yate Loon medium flow.
Posted on Nov 26, 2009
    Champion:
  • 363 Answers
Suggest you go to appliancefactoryparts.com
Posted on Jul 19, 2009
MODEL #HAW18ABB
www.haier.com/us/servicesupport/overview
Jun 11, 2014 | Haier HVTS18DABB Wine Cooler
The top fan is not working and is heating up top compartment. The fan seems to be stuck.
remove the back metal panel and unscrew the top fan and unplug the terminal the cable plugged into the board. I spread disc brake cleaner and then wd-40 into the coil area with a fan spins. manually spin the fan with your finger a few times to get the lubricant evenly distributed. I had the same with my top fan and if the same
Mar 17, 2013 | Haier HVTS18DABB Wine Cooler
I need to know where the board RF-5210-56 is located on the wine cooler model hvts18DABB
Number 19 in this photo is the control boards location=> HVTS18DABB Parts Breakdown
and if you need the user manual click here=> HVTS18DABB User Manual Please rate this if helpful and should you have more questions please ask, Thanks Sea Breeze
May 09, 2011 | Haier HVF042 Wine Cooler
Top fan is not working
The HVTS18DABB wine chiller is truely a piece of **** when it comes to their fans. I have had top fans in the top chiller fail. Solution: Don't buy the replacement part as it will only fail again. Instead, go to your local computer parts store and purchase a high quality 120mm computer fan with a good motor and bearings. On the old fan, snip the wire harness as close as possible to the fan body. On the new fan, remove the connectors that come on the fan. Attach the red wires and the black wire and wrap each with electrical tape. Trim back the yellow wire and tape the end, isn't needed. Remount the fan and you are good to go. i plan on replacing the bottom fan soon with a quality PC fan as well.
Feb 19, 2011 | Haier HVTS18DABB Wine Cooler
I have a Haier HVST18DABB wine cooler, and the upper fan has stopped working (appears to have seized up). What are my options for replacing the fan? I have removed it from the unit, and it is marked...
Hi Bill,
Not sure if you got an answer to this question or not, but I had the same issue and thought I'd reply just in case you still needed help. I was able to order this part for about $30 (including shipping and tax) from http://www.partstore.com. The item number for the top fan is RF-2750-44 and the number for the bottom fan is RF-2750-45.
Based on other posts on this site and other sites it seems that the upper fan dies on this particular model quite a bit.
Andrew
Jan 22, 2011 | Haier HVTS18DABB Wine Cooler
The control buttons don't effect temp. They don't change when pressed. I this something I can fix?
Thank You, I have been transfering the manuals for parts over along with information about these units and has taken time. OK Click Here=> HVTS18DABB Parts Breakdown In that photo you see your Digital Logic Control Board Part RF-5200-141 and there are only 4 in stock in the USA for your model. Now I believe the problem is the Control Board Part Number RF-5210-37 and shown as number 20 in photo. It also appears that there may be a delay on that part from one supplier for up to 14 days yet Haier is showing 10 in stock and 25 on order and a 10 day delay. Click Here=> HVTS18DABB User Manual I will also provide the Service Manual on my site later today. At the moment there is no photo for your part so click Here=> Appliance 911 I can get any of the parts for USA and Technical Questions answered. I will place a clickable link for you part soon under the photo of the HVF042ABL, Thanks Sea Breeze
Dec 10, 2010 | Haier HVTS18DABB Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
Cooler is not cooling and the back of the cooler is hot. product hvts18dtbb
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | Haier HVTS18DABB Wine Cooler
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Logo
782 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Haier Furniture Expert? Answer questions, earn points and help others
