Question about Dryers
Drier turns on, tumbles, no heat - Dryers
Your heating element is out,. very easy to replace
Posted on Jul 18, 2009
  • 199 Answers
It could be many things. Check the lint filter first. You might try checking under the drum where the blower assembly is at for excessive lint build up, check for air gaps in the drum chamber where air can get through. Check the fins of the blower wheel. This blower pulls the air through the drum from the element.The heating element my be burned out or the thermocouple (Temp Sensor) or the circuitry has malfunctioned, the microprocessor firmware has a "bug", Is the dryer on "Fluff" or no heat setting? Make sure it is set on Auto Dry or Permanent Press. Still no heat? If you are handy at disassembly/reassembly then you could check the resistance of the heating element disconnected from the leads. It should read between 10 and 15 ohms. The pre-heat thermistor may be open as well. Unless you are experienced in testing live systems I would take it to your friend who does this stuff for fun or a living. Please check the lint factor, the settings, and then the elemnt. Post again with your findings and we will work from there. Good luck to you!
4 Suggested Answers
  • 1462 Answers
SOURCE: WHITE kNIGHT tUMBLE DRIER THAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Posted on Sep 05, 2008
SOURCE: Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Posted on Oct 21, 2009
  • 9 Answers
SOURCE: My tumble drier has no heat and the reset button
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
Posted on May 02, 2010
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Jul 16, 2015 | Candy Dryers
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Jun 21, 2010 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
How to fit a servis tumble drier fan
Access from the back panel. When the panel is off, you can see it to proceed. Good luck.
Jan 02, 2010 | Dryers
The tumble dryer tumbles but I have no heat and the filter light
Since the heating element is not heating up when powered up you must have a bad heating element.
Oct 06, 2009 | Candy CDC266 Dryer
Drier tumbles but will not heat up, checked for
check you legs on the plug it might have a bad leg (prong) or you need a new pig.
Jun 05, 2009 | Kenmore Dryers
TUMBLE DRIER-INDESIT IS70C
hi did u check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | AEG Washing Machines
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Dryers Logo
108 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
