Question about PC Desktops
Sound card wont play root media files
My new mobo is a biostar when the sound card was installed it found and put it in i can play sound files through media player and a dvd player however system files will not play. the control panel says no audio device however the device manager has it working correctly . i bought a new card and got the same thing the on board audio has been disabled in the bios i have a turtle beach riveria sound card ive installed the chipset drivers with board. the sounds it will play seem to drag a little.
    An expert who has answered 500 questions.
  • 508 Answers
Re: sound card wont play root media files
Hi Hughdog
well, Biostar mobos are know for a lot issues, but depending too, on the OS, windows XP I presume, go on safe mode, and uninstall all audio drivers, and disable on the BIOS audio. then start the PC, and install the audio card. or if is a internal audio reenable again, redetec the drivers, and install them according to the CD and drivers. you should see the play device now and play music correctly.
good luck
Posted on Nov 19, 2007
0 characters
3 Points
My sound is real funny like chipmunk sounds
If the pitch of the sound being played by your computer speakers has changed dramatically or songs and videos are playing faster or slower than they typically should be, the problem is with the sound speed on your computer. This could mean a hardware issue with your speakers or sound card or a software issue with the program that you're using to play a digital media file.
Double-check your speaker connections. If one of the audio cables that runs off of your speakers isn't plugged correctly into your computer, this could cause the audio coming from them to speed up or slow down. Make sure all cables are properly connected to their proper inputs and try to play your audio again. Update the driver for your computer's sound card. Go to the website of the company that made your sound card and look for your unit's product page. Under the "Support" section, click on the download link for the latest device driver. Once the file is on your computer, double-click on it to install it. Then restart your computer and try to play your audio again. Make sure you haven't accidentally sped up or slowed down the media file you are trying to play. Many digital media programs like iTunes or Windows Media Player have features that allow you to play a song or video in slow or fast motion. If this becomes accidentally selected, the audio will also be in slow or fast motion. Click "Stop" to stop your media file from playing and then click "Play" again to allow it to play normally. Restart your computer. This will free up system memory when your computer restarts. If your sound was playing too slow or too fast due to an error with not having enough memory to play properly, that error will now be fixed and your sound should return to normal speed. Hope this helps.
Dec 28, 2012 | eMachines PC Desktops
Cannot get sound on any outlet port
Download and install Media Player Classic and use it.Are you using onboard audio or an add-on card? Make sure that the BIOS is set for one or the other (in other words, the internal audio disabled when using an add-on card), and installing the latest drivers for all.
May 12, 2012 | PC Desktops
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur;s not worth this much effort....
the kind of work u have seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | PC Desktops
Can't install sound card
Try uninstalling it, look on the Biostar website and update your bios drivers, if there is a onboard soundcard disable it, it may be conflicting with your current sound card.
Apr 22, 2009 | PC Desktops
Try 2 use wndws media player, says prblm w/sound device
Do you have a soundcard installed or do you have onboard sound?
If its onboard then the Realtek AC97 driver will probably do
Knowing what mobo you have will help
Apr 20, 2009 | Dell Dimension 4600 PC Desktop
Pc wont play cd or dvd
On many CD-Roms, or burners, there is a plug on the back that is for Digital Audio. It is a rectangular shaped plug. Some PC's require that a cable is attached from the back of the burner, to either the on-board audio (on the motherboard), or to the sound card that may be installed. If you have any further questions, just let me know :)
Mar 06, 2009 | HP Pavilion M9040N Elite Desktop PC
Windows not loading
Appreciate the direct "Ask Me".
Whenever Microsoft Windows XP is installed on a system, the OS is binded to the motherboard, specifically to the chipsets. I am assuming that when you replaced the motherboard, the OS was not reinstalled and it was still binded to the original Dell Dimension board, most likely an Intel 925X Express chipset. When the OS started to load, it could not find the original 925X chipset and instead finds itself confronted with Biostar VIA P4M900/VT8237A chipsets which is an unknown, hence the BSOD.
You could try:
  • boot from CD drive with an XP installer and use the second repair option;
  • boot into Safe Mode (F8) and try to uninstall the Intel devices entries (except the CPU) and allow the system to auto detect (if it will) the new hardware;
  • backup your files and perform a fresh/clean install on the new motherboard.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 05, 2008 | PC Desktops
Windows media player cannot play the file because there is a problem with the sound device
u r install *********** board CD - if no download in your
mother board brand in see in internet & install If' can't so u
Purchase new sound card.
Aug 02, 2008 | PC Desktops
My speakers wont work
1. Check if its plugged into the right audio slot which is the green one on the mobo.
2. Check if its not on mute and or turned down on the volume master control which can be found in the control panel.
3. when you try to play and audio file does it give you a sound error?
Jul 24, 2008 | PC Desktops
Bad direct drivers.
Dear sir,
I ahve problem like My laptop is C700 series of compaq(C772TU) I ahve changed it OS from vista to XP and now there is no audio output whenever I try to play a song it gives msg like " Please installproper device or select another device in configuration Error code: 88780078"
please suggest me proper solution
Mar 22, 2008 | PC Desktops
PC Desktops Logo
231 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
