Question about Air Tools & Compressors
My compressor won't come on and the trip breaker on the compressor keeps going off and stopping the machine from running?
  • 3 Answers
Sometimes when you have too long of an extention cord hooked to a compressor, it can cause the breaker to trip due to too much resistance in the power line. If you are using an extension, try to plug directly to oultlet or get a thicker gauge cord.
Posted on Jul 18, 2009
It turns on and builds pressure but at times stops because the circut breaker for my house trips off.
if the house circuit breaker trips ,it indicates an excessive current draw for the machine
could be a faulty start / run capacitor or partially failed motor.
have an electrician check it out
May 31, 2015 | Air Tools & Compressors
Why does air conditioner trip circuit breaker?
call the technician
indicates a compressor problem
could be a failed start/run capacitor or compress failure
Nov 19, 2017 | Heating & Cooling
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Unit trips breaker after running for short period of time. compressor is extremely hot and has odd smell.
From hat you have described, it sounds like the fan motor or the compressor is overheating and you should stop using the unit immediately. Especially, since it's tripping the circuit breaker. As far as how to repair it is concerned, you won't be able to tell if it's repairable until it's dismantled and all the systems are checked. Plus, Fedders as you knew them, when you purchased this unit, no longer exist. Some parts are still available, but they are in few supply. You may simply want to replace this unit.
Hope this helped you. Please let me know.
Jun 19, 2011 | Fedders R6DH45X Dehumidifier
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
The outside unit keeps tripping the breaker. It will run for a few seconds, loud rumble, then stops, and does this for about five minutes before tripping the breaker. I just bought the house. The unit is...
there is a process to go thru for checking the unit to see which part is causing the problem. first thing, listen to the compressor when it first tries to start. if the compressor does nothing and the breaker trips then you will have to check the compressor. turn off the power to unit.
remove the cover on the compressor where the wires enter the compressor, remove the wires from the compressor you will have 2 terminals that are sealed into the compressor check with a ohm meter and from one terminal to ground and see if you get a reading you should not get a reading to ground on either one of these two terminals. if you do your compressor is bed
Aug 23, 2009 | Ruud UBHC Air Conditioner
A/c is drawing 20 amps and keeps tripping breaker after running
If the fan is running and the compressor is getting hot and tripping off you may have a failed capacitor.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Air Tools & Compressors Logo
106 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
