Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
I was using my weedeater yesterday when it killed on me, now i can't get it started. I have checked the spark plug and changed the gas ect. any suggestions on what is going on?
Well, my 125l is the biggest peice of **** I ever owned... from the time I bought it, It has been nothing but a headache. By the time I get the damn thing started, I am not able to weedeat... I bought me a Stihl, Gosh, sems like I have died and went to Heaven.
Posted on Jun 20, 2011
My Weedeater Model Wer500 tiller won't start Changed oil, drained old gas. Changed spark plug. If i add gas to the carburetor piece. Will run for a short time until the gas run out. Gas not coming in
the carburetor needs a rebuild kit installed. cheap to do and fairly easy. also check your fuel lines, filter to be sure they are in good shape
Oct 05, 2016 | Garden
It cranks, but why won't it start?
HI Luann:
I'd pull the spark plug(s) and clean and dry them, then check for spark.
It's possible they got wet with fuel when the start with kill switch on was tried.
Sep 01, 2015 | 2012 Kymco Like 200i LX
Why does my 86 2.9 l. ranger kill spark plugs
your truck is running too rich with fuel if you have a carburator have it check
Sep 18, 2012 | Cars & Trucks
Weedeater blower model BV 200 won't start after replacement of spark plug.
make sure you're getting gas, spray gas into air intake and see if it runs. if it does, and stalls aftewards, keep spraying until old gas is used up, also, if this does not work, check to see if you have spark
May 31, 2010 | Garden
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Have a Ryobi CS30 Weedeater, will not start, it is about a year old, did not see a spark, just bought new plug.
If you still don't have a spark with the new plug, then you may have a kill switch wire grounding the motor, keeping it from starting. If it's not that, then you have a bad ignition module (coil).
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My weedeater edger over heats and freezes up. it gets very hot, smokes around the spark plug, the spark plug is coverd with soot and it won't start again
Are you using mixed gas? The gas needs to be mixed 50:1
You will have to use 2 cycle oil. If you are using mixed gas, than you can buy a cooler spark plug.
Sounds like the spark plug is not properly gapped.
May 23, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Poulan Pro 200 Leaf Blower won't start. I have installed a carb kit with no results. The spark plug was wet before the new kit---it continues to be wet. I have tried a replacement spark plug with no...
Alright, remember that 2-Stroke motors are meant to do 2 things:
Break down, then Frustrate you.
So, here we go: (Electrical)
Rotor Magnets, Magneto (ignition coil), Spark Plug Wire, Spark Plug, Spark Plug Ground (Cylinder Head).
In that order!
Check your "fire" from the Magneto:
1. Check your Kill Switch. In other words, leave everything normal, and unhook it. Did she start? Kill Switch it is! Kill Switch/Wire comes from the Magneto (single wire/ground) to the Switch itself. So check that wire AT the Magneto (Is it loose and grounding out? Is the Kill Switch grounding you out where it is, because of crud, junk, or because it is touching the block when it is not supposed to?)
2. Check your Spark Plug Wire. Easy, unook it from the plug, stick your finger in, give it a crank (non-MultiMeter way). Did you get shocked? Then it ain't your Plug Wire and Magneto!
With a Multi-/Volt Meter, simply hook her up, and check for juice WHEN you pull the rope. If you got juice, it ain't your Plug Wire or Magneto!
Checking Spark the "normal" way: Grab the Plug with a pair of insulated pliers, hold the plug end against the cylinder head, and pull your rope. Any Spark? What color?
3. STILL no fire. It leaves: Magneto and Plug Wire.
Luckily, they are both in the same place! Tear your blower down, and check to see if the Magneto has slipped out of place (gap is WAY out), or if the Plug Wire has worn to the point it is grounding you out. While you are there, check your Kill Switch wire, to see if she is grounding you out then and there.
4. STILL no fire. That means: Magneto Failing, or Magneto JUNK.
Buy another one, replace it! (Or steal one from another junk Blower/Weedeater. These things are fairly standard, and easy!)
Or, Bad Plug Wire. Meaning she has failed out on you.
Wait......that means: Replace your Magneto! Lucky the things are built together right?
Apr 22, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Gas weedeater wont start
assuming weedeater brand weed eater, the carb. has a filter screen, that blocks and does not allow the pump to push sufficient fuel. A phillips head screw on the side of the carburettor secures a square plate, remove the screw and plate and gently brush the screen clean, dirt collects on the visible side.
Dirty foam filters if fitted change the fuel mixture and make it too rich to run.
and the fuel mixture knob, although secured by a tension spring, moves and may need to be readjusted
Jul 30, 2008 | Electrical Supplies
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
407 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
