WATER LEAKING WHEN AIR IS ON
WATER LEAKS ON PASSENGER FLOOR OF OUR 2005 CHEVY TRAILBLAZER WHEN AIR IS ON
    Problem Solver:
  • 10 Answers
You need to clean out your condensation drain tube it is probably plugged with debree
Posted on Jul 18, 2009
A hard to find water leak on 2005 chevy trailblazer 4.2. i think its the resivoir or a hose but not sure exactly, is there a common leak with this vehichle in that area?
Use a white paper towel and dip it on wet spot, if no color then it is water, probably from A/C accumulator which is normal for all vehicles with A/C, if Pink (dex-cool) or green its antifreeze which could indicate a problem. No towel?, taste it on end of your finger, sweet means coolant no taste means water. Do same thing for wet passenger floor area to determine fluid. If sweet or colored there is a coolant leak from the heater core , if water it would be from some other source unless heater housing broken and rani water leaking down from the heater fan cage.
May 25, 2014 | 2005 Chevrolet Trailblazer Ext
Water leak problem on passenger side floor board of 1992 chevy caprice classic. Need help???
either the air conditioner condensation drain is clogged orb the heater core is leaking .
Nov 19, 2013 | Cars & Trucks
Water leaking on to passenger floor from air conditioner
sounds like a heater core. when one goes bad it leaks onto passanger floor.
Apr 12, 2013 | Bosch 2005 Saturn L300 Cabin Air Filter
2004 chevy trailblazer leak n antifreeze from behind fan
the fan you are referring to is inside the trailblazer on the passenger side behind dash near floor wall? If this is the case it is the heater core and needs to be replaced by a professional. If is is under the hood in the engine compartment it is the water pump in need of replacement? thanks good luck on the heater core..
Aug 28, 2012 | 2004 Chevrolet Blazer
Water leaking into passenger side of floor
This is when the air conditioning is running? The ac evaporator csae drain tube may be plugged The tube is located on the passenger side firewall.Generally I will use a small pick to dislodge debris from the tube being extremely careful not to go into far as the evaprator core may become damaged and develop a leak.
Aug 17, 2010 | 2004 Chevrolet TrailBlazer
How to clean out the condensation tray in a 2005 Chevy Cobalt -
Find the end of the condensate drain tube under the vehicle (passenger side) and clean/blow it out -- it's clogged.
Charlie
Aug 25, 2009 | 2005 Chevrolet Cobalt
2003 Chevy Trailblazer leaks a/c condensate on passenger floor.
under car pass side just behind tire on firewall looking for tube that makes 90 degree bend make sure not clogged if still leaking check for cracks in the evap case
Jul 29, 2009 | 2003 Chevrolet TrailBlazer
Water on passenger floor...
Two things: If there is a stickiness or sweet smell to the water, your heater core may be leaking.
If this is just a summer thing, your a/c evaporator drain tube my be blocked/clogged or leaking inside the vehicle.
Jul 24, 2009 | 2005 Mazda 3
Water dripping on passenger floor from evaporator
could be but if it smels sweet then it's a bad heater core. or bad heater core hose leak.
Jun 24, 2009 | 2004 Chevrolet TrailBlazer
Heating & Cooling Logo
172 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
