Question about Toshiba 32A33 32" TV
Volume have to crank the volume all the way up to hear sound
    Problem Solver:
  • 9 Answers
Re: volume
the volume switch might be faulty,some times you can clean it BUT unless you know what you are doing PLEASE DO NOT do this your self as you will get a electric shock,the other thing it might be is that the audio transformer is at fault,if this is the case then will you have to take it in for repair.hope this helps you.
all the best..Lee Bruce.
Posted on Nov 22, 2007
0 characters
3 Points
Volume isn't working
unplug the tv for a couple of minutes and plug it back in it will reset it...thats worked for most people.
Sep 11, 2012 | Spectra Logic Hello Kitty 13" TV
My tv has no sound
increase the volume to max level .close yourself to TV speaker and listen.if could not hear anything,just turn it off and turn on if you could not hear at least pop sound from the speaker,you will have to replace new speaker.if you are able to hear Buzz noise or very low sound ,sound circuit has to be repaired.
Jun 15, 2011 | JVC Standard (CRT) Televisions
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
RCA Guide Plus Gold Gemstar 27 inch Entertainment Series has perfect picture no sound. The speakers are ok have tested them. When tv is turned on and dvd player is on shows perfect picture but can only...
On the left hand side of the remote control there is a blue or diferent kind of small sercle round buton (mute) push it once and turn the volume up till you hear the volume.
Nov 06, 2009 | RCA Standard (CRT) Televisions
Static noise and when put on max volume still not
sounds like blown speaker inside set. have you tried an external sound system?
Sep 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have no sound!
Are you using a cable box or is your input through the coax cable or antenna? If you are using a cable box with RCA connections make sure the Red and Black cables are securely plugged in both the cable box and the TV. Check to see if your TV has sound by going to the antenna input and select any channel and crank up the volume. If you don't hear anything you'll probably need a new TV.
Jul 08, 2008 | RCA F27615 27" TV
hi there, a bad redeption is a tunner problem, with it a sound section is connected. a weak sound is a amplifier section, try to see if there is a cold solder on the board. test some parts. ty
Dec 29, 2007 | Standard (CRT) Televisions
Tv rca televison model DZ7649 Entertainment series
  • there is a loose contact in volume control or switch.
  • clean volume control with cleaning chemical & change volume switch.
  • hope this will help.
Oct 12, 2007 | Standard (CRT) Televisions
There is no volume coming from my RCA television
chick the speaker, if the speaker working. try to replace sound ic
Jul 10, 2007 | RCA 32V420T 32" TV
Toshiba 32A33 32" TV Logo
46 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
