Question about Sony Televison & Video
Sony Bravia KDL-32M3000 Horiziontal bars on picture
I purchaced my sony bravia on 11/18/2007; after about 1 1/2 years I suddenly started seeing horizontal bars on the screen when i turned the tv on. After about 15 min the screen would go back to normal. After a couple of weeks of this... it started taking longer for the screen to get back to display correctly; maybe 30-45 Min. now, after about a about about 1-1/2 months, it takes about 3 hr + to go back to normal. Has any one else seen this problem?
    Top Expert:
  • Sony Master
  • 74,999 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jun 19, 2017
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Posted on Jan 05, 2009
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
  • 197 Answers
SOURCE: My Sony Bravia KDL-52W3000 panel is broken. Does
there are diferent versions of panel
Posted on Jul 02, 2009
SOURCE: Sony Bravia 32'' picture problem - Sony KDL-32ML130
I am having same problem, started today, didnt find any solution to this question on forums :(
Posted on Nov 22, 2009
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
My Sony Bravia is stuck on channel 2 and won't respond with the remote or the top of the set channel changer.
I have the same problem. I have the Sony Bravia KDL-40S4100. I can't get it off channel 2. It won't work with the remote, and it won't work on buttons on the top of the console either. The power button on the remote is still able to turn the TV on and off, but aside from that, everything else is frozen.
Dec 15, 2010 | Sony KDL-32M3000 32 in. LCD Television
Manual for a sony bravia model KDL-32M3000
Click Sony Support to download user manual free copy for KDL-32M3000
Aug 29, 2010 | Televison & Video
Sony Bravia KDL-32M3000 Has sound, no picture, back-lights are on, red lines flickering across the screen which seems to prove there is video present. I'm thinking T-Con board. I ask this question because...
There is no way to really check a T con without a lot of test equipment, only thing that is serviceable on that board is the small fuse that is by the LVDS connector...
Dec 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
May 06, 2010 | Sony Bravia KDL-46VL130 TV
Slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part:
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Premium TV Tech
Sep 23, 2009 | Sony KDL-32M3000 32 in. LCD Television
Please intimate exact model of Sony TV to look for its screen price info.
Jul 10, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Apr 08, 2009 | Televison & Video
Sony Bravia KDL 40S20L1
You should have a 1 year warranty from Sony. Call them before it expires. This is probably a LCD panel issue.
Oct 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Open Questions:
Televison & Video Logo
136 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
