The purge light is blinking on the honeywell box on my ac box in house.its been draining alot of water from the pipe that leads out side.been doing this 4-5 days.is this normal?
  • 614 Answers
If the ac is cooling you will get a lot of water out of the drain as much as 17 gallons a day. The purge light blinks on some of the Honeywell board when all zones call for cool or heat. Russ
Posted on Jul 19, 2009
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
My 2005 Grand Prix has no heat and my gas mileage is awful. would changing thermostat fix problem. also at night not sure if this has anything to do with problem only my blue temperature arrows light...
A FAULTY THERMOSTAT STUCK OPEN WILL EFFECT GAS MILEAGE AND CAUSE POOR OR NO HEAT CONDITIONS.THERMOSTAT NOT A HARD JOB TO FIX.ALL YOU NEED TO DO IS DRAIN OUT SOME OF THE COOLANT IN A DRAIN PAN.DRAIN COOLANT LEVEL BELOW THERMOSTAT.IF YOU HAVE 3.8L ENGINE THERMOSTAT HOUSING ON TOP INTAKE MANIFOLD.IF YOU HAVE 5.3L ENGINE FOLLOW TOP RADIATOR HOSE IT WILL LEAD YOU TO THERMOSTAT HOUSING.REMOVE HOUSING THERMOSTAT INSIDE THE HOUSING.IF YOU HAVE WATER INLET ANDTHERMOSTAT IN ONE COMPLETE UNIT OR HOUSING YOU HAVE TO REPLACE THE ENTIRE WATER INLET HOUSING WITH NEW THERMOSTAT.THIS TYPE UNIT WILL HAVE LONG PIPE WITH BYPASS PIPE WITH WATER INLET WITH THERMOSTAT. ONCE YOU REPLACE THERMOSTAT.IF YOUR RED ARROWS OFF AND HEAT STILL DONT WORK THE DEALERSHIP WILL HAVE TO CHECK IT OUT.WITH NEW THERMOSTAT AND PRESSURE CAP.MAKE SURE GET COOLANT LEVEL CORRECT.SEE HOW HEAT WORKS.IF NOT YOU HAVE A ELECTRICAL PROBLEM AT AC AND HEATER CONTROL SWITCH.
Dec 03, 2010 | 2005 Pontiac Grand Prix
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Water leak on passenger floorboard also an ac problem
probably leaking heater core. you may have low coolant level now. the only place water comes in the cabin is for the heater, that has got to be it. the heater core can be bypassed (like my car's is) by simply cutting the hose that leads into the car and leave about a foot, make a big U out of it and plug the other side of the hose into the coolant passage that returns from the heater core and leads into the intake manifold. pretty easy you will need a knife, hose clamps, and common sense. the third one is a little harder to come by! :)
Oct 10, 2009 | 2002 Dodge Grand Caravan
2003 Jeep Cherokee Leaks Water on Passenger Side
Just had ours fixed, look on engine side of firewall, if the outlet pipe in passenger well is a 3/4 inch long pipe projecting forward into engine bay with no tubing leading down towards the ground, the problem is water comes out trickles back with pressure in engine bay to foam seal under the pipe and enters footwell inside car.
Take a piece of rubber tubing and hose clamp it on and direct it down towards ground in engine bay and the problem will be solved!
We have gone from soaking carpet to no leak at all with this simple fix.
Rgds Martin
Oct 02, 2009 | 2003 Jeep Grand Cherokee
There is something leaking uder the glove box on the passengers side. The carpet is pretty wet sometimes. Other times it is only a couple of drips but they are brown in color. What is this?
If this happens only with AC on, your heater housing ac drain is blocked with foriegn mater, drain is located in eng compartment, right side, lower firewall area, the AC evap makes alot of condense water, if this is the problem, with the drain the AC has a good charge in it. as long as your antifeeze level stay the same, you should be good in that area, either way pressure test it, possible heater core, if the color is the same as your antifreeze, suspect that.
Aug 16, 2009 | Jeep Wrangler Cars & Trucks
T8411r1028 honeywell thermostat blank screen where would fuse be?
That thermostat should get power from 24V side of a transformer in the air handler. There should be a fuse in there on the PCB, but just as likely, there may be a 2-wire sensor in your drain trap that will shut it down if it senses water backing up in the drain piping. Clear that line from the outside of your house with a shop vac, cycle the breaker for the air handler if needed. You may also be low on freon, though, so a service call might be a good idea anyway.
Jun 01, 2009 | Honeywell Programmable Thermostat Heater
Water on passenger floor coming from AC drain tube
Sounds like the drainpipe has disconnected from the drainpan or evap housing. This is usually in a direct line with the hole in the firewall, so if you are lucky, pushing the pipe through the firewall and hopefully it is in the correct position to fit onto the drainpan outlet. The only other way is to actually do it by feel by sliding your hand up on the cab/dash side of the firewall and locating the pipe and outlet while someone else tries to push it on from the outside. Hope this helps
May 11, 2009 | Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Honeywell furnace humidifier thermostat & other
sounds like to me you have a condensation pump attached to your hvac system. this can be used to pump water produced during the cooling of your house when in the a/c mode. if you have a typical bypass humidifier, you will have excess water running past the water panel and it must be sent to a drain of some kind. I would imagine the pump is being used to get your bypass water to the drain. another scenario may be that you have a 90% condensing furnace. if your exhaust pipe for the furnace is made out of pcv pipe, it is a condensing gas furnace. it will produce water when it is running. the water if from the combustion gases being condensed in the secondary heat exchanger. this is normal. some condensing gas furnaces will draw combustion air from inside the house and some will have a second pvc pipe that is used to pulll combustion air from the outside of the house. either way, it is not dehumidifying your house. the humidifier should be able to keep up if it is runnng properly. you should have water running out the bottom drain of the humidifier any time the fan on your furnace is running and the humidistat is calling for humidity. if this is not happening, it is not wired properly.
Jan 16, 2009 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
1,506 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
