Question about GE GSS20IEP Side by Side Refrigerator
Water wont stop flowing from dispenser or ice maker
Installet new water line filter to my G E but when I turned the water on it just poured out free flowing not stoping
    Problem Solver:
  • 3 Answers
If you take apart the valve there 2 small rubbers. One of them is gone and you need to replace it. One of them for ice maker and other for the water. The valve is where you plug water dispenser plastic tube
Posted on Jul 30, 2009
    Scholar:
  • 103 Answers
You have two check the water push button, or the valve itself.
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
I have a Westinghouse side by side refridgerater with water and ice dispenser. The other day I arrived home to find water pouring through the back of the freezer section into the ice maker,and into ice...
Your water control has two sides. One side is for the ice maker and other is the water disapenser. If the ice maker valve becomes mechanically defective the water valve can allow water to continue to flow or not flow at all. Replace the water control valve and I believe this will solve this porblem, Thanks Sea Breeze
Dec 11, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser is really slow coming out and it takes however to make ice. There is no kink in the water line to the fridge.
water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated, ice maker had been making ice prior to this, turned off ice maker to avoid motor burn out.
Dec 26, 2010 | LG LRSC-26922 Side by Side Refrigerator
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
Jun 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Automatic ice maker won't make ice
Turn off water.
Disconnect the line after the filter.
Turn water back on. If there is no water flowing, replace the filter.
If there is water flowing, the feed valve is probably defective.
Aug 02, 2009 | Kenmore Refrigerators
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jan 06, 2009 | Refrigerators
Ice amker and water spickett is no longer working
Hollow ice cubes are the result of poor water flow to the ice maker. I know you already have experienced flow issur since you mentioned poor water dispenser flow. You apparently have a filter clogged, a house supply valve clogged or lastly a clogged water solonoid valve. The filter is self explanitory. You would replace the filter. The house supply valve is next most likely, to test it you would need to remove the supply line at the rear of the refrigerator after turning supply off the turn supply on to check flow. If the flow is STRONG then next most likely is a clogged solonoid valve. To test it you would, with supply connected and turned on, need to locate the plastic tube that goes to the water dispenser reservoir in the refrigerator section. Disconnect the tube at the solonoid valve and place glass or pitcher at solonoid port while someone presses the diapenser lever. If you have poor flow then but had good supply flow, the valve must be bad.
Nov 21, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
GE GSS20IEP Side by Side Refrigerator Logo
220 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
