Question about Wolfgang Puck Bistro 1700 Deep Fryer
My deep fryer will not come on i used it and cleaned and then when i try to use it the nest day the power will not come on
  • scmartin6 Jul 18, 2009
    I have a wolfgang puck bistro deep fryer and it will not come on. I used it yesterday and cleaned it but when I tried using it again it will not power on. Can you help?
  • 491 Answers
CHECK FUSE IN PLUG HAS NOT BLOWN DUE TO WATER CONTACT
Posted on Jul 18, 2009
My deep fryer is working but once or twice a day the door of the fryer will suddenly open with a thud! Scaring all in the kitchen. If we keep the door open then the problem goes away to some extent. Lot of...
It is advisable to get a qualified technician to clean the burners, pilot, and insure there is proper gas pressure and volume to the unit. Without verified gas pressure and volume, even with clean burners the problem may recur.
Jan 16, 2013 | Vulcan EF3 Deep Fryer
Fryer wont turn on since I cleaned it
I don't service home models, only commercial products, however I would guess that something got wet somehow? Let it dry out for a few days and even a week or so, and then try it. If not, I would junk it and buy another...
Susan
REO
Nov 17, 2011 | GE 168997 Deep Fryer
When i went to go use my deep fryer the other day
If it uses the DP16 cordset, that is probably your problem. If not, find and press the reset button.
Solution for fixing DP16 Cordset for GE deep fryers: To begin with, you willl need to clean the electrical contacts on both the fryer and the cordset. They will be burnt from electricity arcing between the two when the cord is plugged into an outlet before connecting to the deep fryer. I used a dremel tool attachement grinder used for sharpening chain saw chains. It is cylindrical and fits in the holes in the cordset perfectly. You could use sandpaper rolled into a small cylinder, or whatever is available that will do the job. To open the flaps that cover the holes, insert a toothpick in the center hole of the cordset while you work. Make sure that both sets of contacts are completely clean before proceeding with the next step. Next, using needle nose plyers, make two tight coils of fine or extra fine (.032") resin core solder the same size as the holes in the cordeset. Press into place in each of the holes in the cordset against the electrical contacts. Spread the coils a little so they cannot fall out when the cordset is not attached to the fryer because the flaps will likely not close properly or at all. You can work the coils down so the flaps will close if you use the .032 solder, but they will still be a little loose, so they might jam the flaps open or partially open. This definitly isn't a UL approved method, but it will fix the problem completely. Happy frying!
Mar 12, 2010 | GE 168952 Deep Fryer
How oftern should a deep fat fryer Oil be change and unit be cleaned
It depends on how much you use it. If you use every day all day them change oil once a week and cleaned at the same time. If used rarley then change oil when food tasted not as good as it shood.
Sep 10, 2009 | Imperial IFS40 Deep Fryer
Can you remove the bucket (part that holds the oil) on a CF153 ?
It should come out, because you may have to replace it one day. You may find the screws for it on the bottom side of the vat. Does it not have a spout at the bottom of it ?
Feb 13, 2009 | Rival CF153-WM Deep Fryer
G.e.deep fryer g.e.168997
Spray it really well with Oven Cleaner-let it sit outside, if you can for as long as possible-a day would be great. then wipe it down with a damp sponge.
Jul 31, 2008 | GE 168997 Deep Fryer
Not working anymore
Maybe you should get a new deep fryer.
May 01, 2008 | GE 168997 Deep Fryer
Deep fryer
it needs to be completley cleaned out
Feb 11, 2008 | GE 168997 Deep Fryer
Kitchen Appliances - Others Logo
163 people viewed this question
Top Wolfgang Puck Kitchen Appliances - Others Experts
Steve
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
