Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printer not reading print command brothermfc 7160c
Trying to print from pc but printer won't print
  • 62 Answers
Dell 2155cn Installs without error, but won't print
Most router (DHCP servicer) issue an IP to any device on the network, is your PC on the the same subset of the network? Can you ping the printer? Check your printer and device property, make sure you have the same IP address and you're on the same subset.
Feb 02, 2012 | Dell 2155cn and 2155cdn Color Laser...
Printer suddenly will not communicate with the computer. Tried unplugging both wall plug and usb plug. Printer can print but only test page. Tried to uninstall, but computer won't allow me, gives error...
Have you tried rebooting your PC? Do you see a printer Icon in the taskbar (right corner) if so click on it and you may see several que's and the printer is bound up, so-to-speak. The reason your able to do a test print is because that command bypasses any que's in memory. Turn your printer power off, then reboot your PC. Onces its booted up, turn on your printer. This will clear any que's and your printer should communicate again.
Let me know if this help you.
Thank you
Jul 04, 2011 | Computers & Internet
P330i - The printer says Ready on the LCD but the computer reads Out of Paper? There are cards ready in the hopper?
please install the driver again, then send the command IM (print testcard)
If not work, Try to send !SA command and then try to print the card.
Oct 08, 2010 | Zebra P330i Thermal Card Printer
Hi, I?ve critical problem. I have a printer HP 1020 which is installed with my pc. And we have 10 PC in my local network. We use above printer share basis. But problem is when some one (without my pc) try...
The spool service basically holds what you want to print in memory and print it while you can do other stuff..
Check you spool settings here:
Although you can control whether to use spooling or not, you'll typically want to spool documents you send to printing. Spooling documents expedites the printing process, and allows the application that sent the document to release control back to the user much faster this link will show you the settings you can select but the real settings will take place inside your printer properties.
http://technet.microsoft.com/en-us/library/cc739118(WS.10).aspx
Hp 1020 spooler settings, unable to find the specific one but i believe when you go into the options just follow the steps provided in the link with similar images and try selecting a different spooler option, this can indeed affect what's happening with the printer versus the systems...
http://technet.microsoft.com/en-us/library/cc722526.aspx
Aug 12, 2010 | HP LaserJet 1020 Printer
Can't access Brother MFC-490CW printer using D-Link 628 wireless
You will have to reset the "Path" to the printer, so the "Client" PC can find it. EG: \\MSHOME\Brothermfc, also ensure "Sharing" is enabled in Properties on "Main" PC. Also ensure you are all on the same "Workgroup" & PC's have a "Name", and the "Printer" is installed on the "Client" PC too. and you can print a test page from the clients too..
Feb 03, 2010 | Office Equipment & Supplies
It won't print anything, the command would be
you have lost your printer driver .
delete the original one in add and remove section and re install it and it should be printing after that
Sep 28, 2009 | Office Equipment & Supplies
Can't delete print job for an Epson C** printer
I don't know which OS you have. I will assume it is a newer OS like WinXP. You have tried to reboot the PC I'd imagine. Try stopping the print spooler by running the following command from the cmd prompt.
net stop spooler
Then check the print queue and see if you can manually delete the print job. Then issue the command
net start spooler
Jan 30, 2009 | Epson Stylus C88 InkJet Photo Printer
I need to learn how to scan a document and save to a file. I have a BrotherMFC-3240C machine.
This link will help you to learn how to scan from your BrotherMFC-3240C machine. I hope this information help you. Khaled
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000240/BH3_UsaEngSoft_C.pdf
Oct 21, 2008 | Brother MFC-3240C All-In-One InkJet...
BrotherMFC-235C status monitor shows ink is empty,but its new ink,and wont print
we called asus and we had to delete a filter in the main program.problem now solved.
Sep 26, 2008 | Brother Office Equipment & Supplies
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Nov 11, 2007 | Brother Multi-Function Center® MFC-215C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
