Question about Dryers
Sparks from starter switch wires
Starter switch popped off and hit inside wall panel and sparked melting the tips of wire connectors, changed all connectors and put them back on starter switch (after testing it of course) and now dryer will not start but you can hear it trying to run just no heat and the drum doesn't turn WHAT GIVES?
    President:
  • 1,922 Answers
You may have lost one leg of power at the panel if fused or on 2 single pole breakers,or you could have burnt the neutral connection somewhere inside the unit
Posted on Sep 26, 2009
SOURCE:
When sparks fly from connector to electrical main panel and to me it means overheating of wire, what kind of danger can it caused to other wire (or circuits)sharing the same conduit?
Overheated wire can catch wire and melt other wires.
Sparks from a loose connection usually will not damage other wires, unless the short circuit has been going on for a while... but usually a short circuit will trip breaker or the arcing will completely short out and no more electricity will flow
http://waterheatertimer.org/Troubleshoot-household-electricity.html#spark
http://waterheatertimer.org/Color-codewire.html
Problem can be undersized wire and breaker or mismatched wire size and breaker rating
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 11, 2015 | Electrical Supplies
Autozone told me that my wiring for my 93 buick regal was messed up on my alternator I thought my starter was killng the battery so I had them test it but that's when they said its the wiring to your...
Does your battery have a large spark when you connect or disconnect it? A small spark may appear. A large spark would be a large drain.
There should be a wire from the starter or a junction block that goes to the plug on the alternator. It is a voltage sensing wire. It is also a fusible link. If the wire is not melted away (thats how they work as a fuse) it may be corroded inside the white (or black) plastic connector.
Remove the plug from the alternator and check the larger wire on it for 12 volts.
The other end of the wire will go to either the starter or a junction block on the firewall or near the battery.
Look for these
Don't just look at them, give a little tug to see if they pull out of the bu-tt connector
And you can go to Autozone.com and they have free wire diagrams in the repair section.madmikers_13.jpg
Oct 11, 2011 | Cars & Trucks
I have spark at the cap but not to the sparks, already change rotr
Ok, heres how the spark works, coil, to cap,, along the rotor to the connection pins of the cap, to the spark plug wires,, and onto the plugs, inside the cap, make sure that the little center piece is hitting the center or the rotor, which goes out to the tip of the rotor,, that sends spark to the pins inside the cap,, now if your cap has any corrosion or tiny cracks,, that spark will go all over the place and not travel down its intended path, so clean off those contact pins in the cap, or replace it, if you have no spark to any of the plugs,, change the cap,, if its just to one or 2 , check the plug wires and the plugs themselves
Sep 28, 2011 | 1990 Ford Mustang
95 astro has no spark to the coil what next
Try this tips:
1. Check the battery voltage at the battery with the digital volt/ohm meter. Set the meter to "Volts D/C" and touch the black meter lead to the negative battery post and the red meter lead to the positive post. A fully charged battery will measure 12.7 volts or more. A measurement of 12.5 volts is considered discharged, and the battery should be charged before any further testing. Any measurement below 11 volts indicates a severely discharged battery--the battery is most likely damaged and should be replaced. If the battery measures above 12.7 volts, proceed to the next step.
2. Check the starter for battery voltage by touching the red (positive) meter lead to the battery cable terminal on the back of the starter and the black (negative) lead to the chassis. The voltage reading should be approximately the same as the measurement at the battery. If the reading is lower than battery voltage, check for bad connections at the cables on the battery and the starter or ground cable.
Check for ignition switch signal at the purple wire on the back of the starter. When the key is turned to the "Start" position this wire should measure battery voltage. If the reading is less than battery voltage, or zero volts, check the fusible links (orange wires) on the back of the starter. If the fusible links are intact and not burned or broken, replace the ignition switch. If battery voltage is present at the purple wire, and the starter doesn't turn, replace the starter. If the voltage measurements at the starter are correct, and the starter cranks the engine over when the key is turned to the start position, proceed to the next step.
3. Remove the air duct attached to the throttle body, and spray a liberal amount of the carburetor spray into the throttle body. Replace the hose, and try to start the engine. If the engine starts, the fuel pump is not supplying fuel or the ignition module is not pulsing the injectors. Check the fuel pump fuse located in the under-hood fuse block. If it is good, check for power at the fuel pump electrical connector located near the rear of the fuel tank on the driver's side of the van. In the Chevy Astro van, power is supplied to the fuel pump by the the gray wire on the electrical connector when the engine is being cranked. If power is supplied, hitting the fuel tank with the flat side of a hammer while someone else is turning the ignition key to start will sometimes bump the fuel pump enough to allow it to start. If the fuel pump checks good, proceed to the next step.
4. Check for spark. Disconnect the coil wire at the ignition coil, and try to start the engine. If no spark occurs, replace the coil and ignition module. If a strong spark occurs, plug the wire back in, and remove a spark plug wire from a spark plug and repeat the test. If a spark is not present, replace the spark plug wires, and distributor cap and rotor.
Keep us updated.
Jan 12, 2011 | 1995 Chevrolet Astro
2001 beetle stopping after running 10 mins. vehicle was hit on right side no airbag or window damage all wiring intact remote will open locks won't close or open rear hatch. Fuel pump,filter checked...
Do you have a "spark"? test: remove a sparkplu wire from a convenient sparkplug and lay it down on a nearby metal ground. Crank ignition and look for a spark from the end of the cable to the metal ground.
Spark? Then it may be the fuel safety cut-off switch (with a delayed reaction) ... mounted in the back, inside a side panel. It cuts off fuel when it senses a collision.
No Spark? ... ignition relay switch or the cable from starter solenoid, most likely.
Sep 19, 2009 | 2001 Volkswagen Beetle
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
97 Jetta will not start
Sounds like there's no spark. Change the ignition coil. This is a common solution for cars that won't start due to lack of spark. To check for spark, pull a spark plug wire and hold it near the manifold and have someone turn the key to crank. If you don't see an arc of spark coming from the wire, this would confirm your spark problem. Hope this answers your question.. Best of luck.
Greg
Jun 01, 2009 | 1997 Volkswagen Jetta
05 crf 450 with No Spark
remove the front number plate and inspect the cdi box, look 4 damage 2 the case then check wiring connectors-should a 4wire and a 6wire block.also check LH engine casing 4 damage (gear lever can smash it if u crash) this is where the stator coil is-which is the power source 4 the ignition system. hope this helps.good luck.
Apr 06, 2009 | 2005 Honda CRF 450 R
Dryers Logo
46 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
