Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Control panel does not respond, filter keeps running
I have the Compool CP3600. Starting about a month ago, the filter keep on running eventhough the panel indicate that the it was off. I had to reset both the panel and/or the power control by pressing on a tiny hole on the panel. It responded for a few time, but now it did not respond at all, and the filter keep on running, and I don't know how to turn it off. Please help!
  • 128 Answers
You have a bad relay. Replace relay and in the meantime use the breaker. You might have a spare relay in the box. Look for a relay without any wires hooked to it
Posted on Aug 30, 2009
Service mode Compool
turn everything off then turn back on if it is still uncontrolable sounds like master pc board
Feb 27, 2014 | Pentair Compool CP3400TX Pool & Spa...
Compool cp3400
when the indoor control start the alarm , did you notice any error code display in indoor control like 170 ? POSSIBLE IS THIS control a pool only or pool and spa combination, did you have a pool heater connected to compool 3400 (PENTAIR)
Jun 14, 2013 | Pool & Spa
Water keeps drain into the refridgerator but it still freezes and still keeps food cold in the ice box I just replaced the filter about a month ago.I also have been keeping a towel in there to soak up the...
Take out the back panel inside your freezer and locate the drip line in there, it should be some where under the coils, check if its blocked up with ice, if it is you need to unclog it. there should also be a wire that runs into that drip line (it helps defrost that line) you might need to replace that wire.
Feb 20, 2013 | Kenmore 64802 Top Freezer Refrigerator
What kind of maintenance should i do to my 1989 cbr 600 f to keep it in tip top running condition
  • Change gearbox oil every 3000 miles. Change oil filter every 6000 miles. Use 10w40 motor oil. NEVER use synthetic lubricants as they can mess up the clutch.
  • Oil the chain every two weeks. Lube the control cables every oil filter change.
  • Keep the gas tank full in the cold months. This lessens internal tank rusting due to condensation in the tank. Drain the carbs when the bike will sit over the winter unless you plan on starting the bike every two weeks and letting it run for 15 minutes each time.
  • Be sure the gas valve is turned off when the bike is not in use.
  • Get a 2 amp trickle charger and charge the battery once a week for 4 hours in the winter. Be sure to keep enough water in the battery to cover the top of the plates in each cell. Know that batteries only last two years or so.
  • Check the chain tension once a month during the summer riding season.
  • Please rate my answer. Thanks.
Sep 11, 2010 | 1989 Honda CBR 600 F Hurricane
I have a Maytag MDB6701AWS dishwasher and the control panel is not responding, the lock light is on but it is not responding. I had the same problem less than a year ago and they said the control panel was...
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Aug 08, 2010 | Maytag MDB6701AW 24 in. Dishwasher
Onan 6500 less than 2yrs old and used once. Try
Your air filter may be stuck with dirt or moist. Try to clean or change it.
In all cases the problem is in the air duct, if it runs well without air filter.
Jul 17, 2010 | Watts Onan Portable Generator - 5000 ,...
Lightning hit our house a month ago and the dryer was running. It stopped and now the start button won't stay engaged l We have to push the button to make it run and tape it in the run position,
your missing the voltage from the control panel timer to energize the relay to keep it energized after you push it to make it start,you need to trace this back to the control panel timer possibly thru a resistor that could have burned open due to power outage and probably replace
Nov 17, 2009 | Whirlpool LER7646E Dryer
Compool 3600 Spa side remote
Do not reset while the motor is running. Reset the CP 3600 when the power is on but with the motor off. OK.
Jun 07, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Pool motor keeps turning off. Runs fine in "Service" mode but as soon as I switch the controller to "Auto" mode, it starts for a second, then quickly turns off. It keeps trying over and over but then it...
Well, since this is brand new, it is still under the normal
warranty period. There must be something wrong with the controller, since it works fine in Service Mode. Just
get in touch the dealer where you buy the unit.
May 02, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Range works, ovens do not
CALL DACOR DIRECT AND ASK FOR MICHAEL, HE IS THE SON OF THE OWNER.
Dacor 1440 Bridge Gate Drive
Diamond Bar, CA 91765 Toll free: 800-793-0093 Main: 626-799-1000 Fax: 626-403-3130
Jul 09, 2008 | Dacor Epicure ER48D Stainless Steel Gas...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
355 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
