This sound comes from the compressor or the fan housing, and it is sound as it is going out soon...you need to keep the unit from getting too hot buy overworking the unit or getting freeze or building ice on the condensing unit, also try to check on the fan and see if it is not secure or it is not moving freely and not from side to side…try to keep it clean to extend the life of it for now…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help.God bless
If the pop noise after turning off cooling or heating. In heating, this is the noise of the refrigeration system changing/adjusting itself and this is perfectly normal.
The boiler won't ignite, i turn it on the correct lights come on (i can hear noises and click but...
(More)
The boiler won't ignite, i turn it on the correct lights come on (i can hear noises and click but not ignition)then after about 1 min the radiator light starts flashing and all noises stop? can you help please
WE have 20'' refer container now it is a repair so we repair or service provider in thane and...
(More)
WE have 20'' refer container now it is a repair so we repair or service provider in thane and bhiwandi.
Split system LG airconditioner is leaking water inside the house after about 30mins how can i see if...
(More)
Split system LG airconditioner is leaking water inside the house after about 30mins how can i see if there is a blockage in the drainage area?
turns on and works fine when it wants to the remote screen always turns on even when the air con...
(More)
turns on and works fine when it wants to the remote screen always turns on even when the air con doesnt
Hi, i've got 2 Emailair remotes which don't work regardless of a change in batteries. Is there some...
(More)
Hi, i've got 2 Emailair remotes which don't work regardless of a change in batteries. Is there some solution? The remotes are in good condition. Or do they have an expiry??? thanks On the back of the remotes is 'RC'. These are for split-system air/con.
