I have the same problem with lots of applications.
You will be needing to find someone who can direct you to the proper bulbs.
Just because the bulb has the same type screw-in base does not mean it will work in all screw-in base applications.
For example, some LED will not work where you have a dimmer switch, even though you have not set the light on "dim".
God bless your efforts.
Adjust the light sensor on the on the housing of the motion sensor.
Testimonial: "ok, now it's getting more strange, I took one of the two bulbs out and put the old incandescent back in and it's working fine. I'll try again tomorrow to see what happens. Thanks for all the suggestions."
