Question about Procom ML300HGA Heater
Hight what is the right hight to put the heater on the wall ?Thanks
  • 4 Answers
The heater should not be closer than 36inches from the cieling. for more info call 1-877-886-5989. any closer could be a fire hazard.
Posted on Jan 14, 2009
    Problem Solver:
  • 18 Answers
1 inch from the ceiling.
Posted on Jan 04, 2008
Punch home designe problem
when you pick wall from floor plan look at tool options to your right. there you can set your wall hights
May 08, 2012 | Punch Home and Landscape Design Suite for...
Hi, I have a small Williams direct vent heater 14k btu that i want to install. for ideal placement, the double wall vent will be against the stud not centered. is this a problem? also can the existing...
The vent pipe CAN NOT touch the wall stud. You can cut back the fiberglass insulation, but it must be a minimum of 6" away from the vent pipe on all sides.
Jan 26, 2011 | Heating & Cooling
My thermostat comes on and runs for a few minutes, turns off and then a few seconds later it comes back on again. I would like to know how to set the minimum and maximum on and off settings.
you don't, you can only set emperature to set differentials can cause problems if you don't have much expertise in the field of thermostats! and the most likely problem with yours is location is it on an external wall if so this can give false readings as temperature from outside can leak through where cable comes onto controller, and its always standard not to put on external wall and it must be above the standard hight of 1.4m this is the most accurate spot to read room temperature as its usually the middle of wall and out of the natural ventilation of low cold air and high hot air that is moving around, another spot not to place is where a window can allow sun or cold to affect. I'm pretty sure that the hole where the cable comes from is leaking in air you should always seal these holes and if not your controller is faulty, because differentials are usually a preset in circuit board as heater tested to work as set so look at the location first this most likely problem or air leakage behind controller
Dec 09, 2010 | Heating & Cooling
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
I need to know how to adjust my headlights eg/ how far back should I be parked and how high up the wall should the beams be for high and low beam
12 METERS THE LOW BEEN SHOULD BE THE HIGHT OF A BUMPER , CONCENTRATED LIGHT SHOULD BE STRAIGHT ON THE LEFT SIDE AND THE RIGHT SIDE A LITTLE BIT TURNING TO THE RIGHT.
Jul 31, 2010 | Toyota Camry Cars & Trucks
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
I need to know the hight ,,when adjusting the
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Sep 11, 2009 | 2001 Pontiac Grand Prix
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
46 sony bravia Lcd tv on a articulating wall mount Whats a Good hight floor to bottom of the tv
The ideal height would be between 38" and 42". with your stand being 42" high I would say 45" would be fine. Anything over 50" off the floor will put strain on your neck and give you constant headaches after watching for extended periods of time.
May 17, 2008 | Sony BRAVIA KDL-46V3000 Television
Procom ML300HGA Heater Logo
41 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
