Open following link for Bosch tankless troubleshooting resources,
including Bosch contact information, typical manuals, error codes, tech
support, parts, fuel-saver calculator, service bulletins, water heater
forum, fixya links, disclaimers, and links for finding service
technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.htmlBefore calling service technician, read manual for fault finding and possible solutions.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch_water-wizard.pdfhttp://waterheatertimer.org/pdf/Bosch_13P_16P_In.pdfFollowing links talk about keeping pilot lit, and describe location somewhat. Bosch water wizard has standing pilot light.
http://www.fixya.com/support/t2961646-water_wizard_10p_pilot_light_keeps_goinghttp://www.fixya.com/support/t2960079-bosh_water_wizard_10p_pilot_light_keepshttp://www.fixya.com/support/t6182021-bosch_10p_tankless_hot_water1) The manual does not show diagrams you asked for.
2) Website that sells Bosch parts does not show parts for water wizard, nor does Bosch site for parts: Instruction manual says: replace pilot injector
http://www.boschhotwater.com/HelpfulResources/PurchaseParts/tabid/837/Default.aspxhttp://www.houseneeds.com/shop/heatingproducts/waterheating/parts/bosch2400espartsbuy.asp#3) Searching "pilot injector for Bosch Water wizard" turns up fixya questions which is generally bad news for do-it-yourselfer because it means information sources are through service technician.
4) As a general rule, tankless are not do-it-yourself repairs or installation because they are affected by so many internal and external factors, including air quality, air flow, venting, other gas appliances, gas pressure, gas supply, water pressure, water flow, plumbing problems, water quality, plus internal parts and including any combination of things listed above..
Replacement parts each come will disclaimer.
Add a comment with your experience so others with same-similar problem can benefit.
Send some photos so the internet can see the problem.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answersAlso take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
