After engine oil coolers were replaced they discovered the the gearbox oil cooler to needs replacing and since it was stripped gearbox makes terrible noise like it's labouring constantly trying to change gears cluck sound, rev counter constantly moving rapidly
The first thing you need to check is for water contamination in the gearbox oil, if none try filling it with the correct procedure and reset adaptations, if there is water in the gearbox do not bother repairing it at a huge cost, they seldom get it right. Rather look for a good secondhand box that is the same make, the most common is the ZF6HP19
SOURCE: 2001 BMW 318i se Coolant
check the cap on the coolant ,i had same prob. if the cap is loose the level of water will change.tighten the cap it can be somthing as simple as that.
SOURCE: speedo & trip counter not working
Speedo has a loose or broken connection behind the gauge cluster.......Odometer needs to have the gears replaced ( inexpensive part), this part can be sourced on ebay or www.bavauto.com
SOURCE: High oil Consumption, BMW M5
Look for Castrol TWS 10W60 Motor Oil. This car should not burn so much oil, you need to use a different kind. It is recommended by BMW as well. I also heard the VANOS isnt an issue anymore, can be fixed with a different MAFF. Good luck!
SOURCE: My car makes a rattling sound under the car
Hey Thealmeidas!
Yep, there's a good chance some part of the exhaust system has come loose and is rattling at certain RPM's. Start fault-tracing by checking if any part of the exhaust seems loose to come in contact with anything, or if there's any loose clamps or similar parts hanging onto it. Another quite common reason for rattle is that some part of the exhaust manifold, such as a bolt or hose/pipe has loosened (often due to rust and/or corrosion).
Another possibility is that it's somehow related to the transmission (since you mention putting it into gear). If so that would be another subject.
Hi Abduragiem
This is a manual or auto transmission?
Bmw 320I Automatic 2007 e90 sedan
