Question about Whirlpool GS6NBEXR Side by Side Refrigerator
The ice maker seems to be frozen up, the bar is up and it has ice but does not fall into the tray. Making a humming sound.
    Problem Solver:
  • 10 Answers
Motor
Posted on Jul 18, 2009
  • Rekox Jul 18, 2009
    Motor module is locked up. PT # 8201515 is motor module kit for that problem. Unit is held inside box with ½" screws. I/m held together with philips screws.
What can I do to fix my ice maker? My ice maker 12685003 in my Amana refrigerator keeps dispensing water and has a huge peak of ice in the tray. It works fine for awhile making regular cubes then it looks...
Most likely your Ice maker inlet valve is not closing properly and seeping water continuously.
This will lead to frozen ice layer on tray or surrounding area in the freezer. Also this water leak from valve will freeze the water line and stop making ice.
Your inlet water valve need to be changed for your fridge. Amana is made by Whirlpool Corporation. Check with your mode number.
If in USA www.repairclinic.com
In Canada www.reliableparts.ca
Hey there are lot of other parts sellers too. Just two of them above
Oct 24, 2017 | Refrigerators
Kenmore coldspot ice maker not working
check to make sure the water hasn't frozen in the tube that it should fill the tray with. Please let me know if this isn't the problem and I can further assist you. If frozen, you should thaw out the freezer to get it working again.
Good luck
Apr 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice Maker bar won't come down
I have not worked on this model before but on the whirlpool they have a bar as well. you can turn off ice maker by pushing it up and it locks in place to stop ice production. if u want it to make ice u push it up slightly and it should move down. also check the ice maker tray to be sure u are getting water to the tray. if u get the bar to go down and no water comes in then check that u have water at the back of fridge.. if u have water there but not in the tray then you may have a bad water inlet valve on back of fridge.
Apr 15, 2014 | Maytag MFX2570AEM French Door Freestanding...
I just changed the ice maker on my jenn aire ref. JCD2289AES. The old one was leaking everywhere and making a big frozen block of ice . It seemed very simple but, it the cube tray is not filling with water...
there is a solonoid valve at the back of the freezer section (externally) which should release 7 seconds of water into the ice tray to fill it..
the most common cause of leaking ice makers is that the valve freezes up if not much ice has been used.. and you simply need to thaw the freezer out overnight (put the contents in a cool box, or wrap it in lots of bubble wrap/newspaper and cool blankets to keep it frozen)
that aside, there is a wire ice-stopper that goes up and down as the level of the ice rises and falls.. if it is in the raise position, the ioce maker won't do anything.. you can gently press it down, and things should start almost immediately.
Oct 02, 2017 | Jenn-Air JCB2388G Side by Side...
Ice maker not making ice. ice in the tray, but will not dump the ice
Its the bar and gears that has frozen.
There is a stainless bar on the front of the ice maker. It move out and back to check for ice in the bucket. This bar is stuck and the ice maker thinks there is no need to harvest ice.
Try to move this bar and I bet it is stuck.
You can get a new Ice maker from Ebay and replace it yourself.
Jul 24, 2010 | LG LFX25960ST Stainless Steel French Door...
Kitchen Aid KSCS25INSS ice making replenishment rate has been diminishing for about a month. Today it stopped dropping ice completely. The ice tray has frozen cubes which will not fall
There could be many reasons for this problem. Because you said the ice maker stopped with ice in the trays leads me to focus on the ice maker alone. I will try to get some photos and links when I return. Sea Breeze
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
May 31, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
230 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
