Question about Maytag MFD2561HE Bottom Freezer French Door Refrigerator
Defrost heater voltage
Are you suppose to have 115v on each side of the defrost heater while in defrost or is it suppose to 115v across the heater.
    President:
  • 1,136 Answers
Hi, Yes there should be 120V when the defrost cycle is on. If not, chack the bi-metal switch and see if it has continuity on it. It must be tested while it is cold. If there is an open circuit, change the by-metal switch. You can try and bypass the bi-metal switch and put the cycle in defrost to se if the heaters come on.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 18, 2009
What voltage should be across the pins on the heater element on a westinghouse sb925
please confirm if the heater element looks like the one on this diagram
http://spares.bigwarehouse.com.au/product_info.php?cPath=64685_79594_79627&products_id=1611198
Is your model operating on 240v AC.
Generally to test heater it is better to check for ohms. If the dishwasher is now working then please clarify why you need to check voltage on heater.
Apr 11, 2014 | Westinghouse 24 in. MDP531 RF...
Ice forming on back of freezer , refrigerator side not cooling GE modelgss22wgpe bb
You frig is not going through the defrost cycle. Locate the defrost timer and advance it to the defrost cycle.(one click). Empty the freezer and remove the rear panel. See if the defrost heater is starting to get hot. Located at the bottom of the evaporator. If getting hot, replace the timer. If not getting hot, unplug the frig and check the resistance across the defrost timer(should be a closed curcit when cold) and across the heater. If "0" resistance, replace heater.
When replacing the heater alwarys replace the defrost thermostat at the same time. Will save you work in the near future.
Dec 28, 2009 | GE Refrigerators
Rear defrost quitlight comes on but does not defrost window
u will need to test the grid for continuity, using a volt meter make sure you have power to the grid at the connectors, if u do move on to testing the grid bars, each one should have power from side to side, the voltage will drop or increase as u move across the grid from the load of the heater bars.
Dec 02, 2009 | 1999 Buick LeSabre
Rear Defroster
12 volts is supplied to the grid across the glass.Turn rear defrost on and check for voltage and continuity across the grid...any broken spot in the grid will cause an open circuit and inoperative heater.
Sep 07, 2009 | 2002 Nissan Altima
No hot water, Rheem Model RR612T, Electric Hot Water Heater, 60 g
If you don't have current, 0v from terminal to terminal, then you don't have voltage to the elements. Replace the thermostat but check that you have 220v to the thermostat. It is possible that your breakers to the unit are either bad or tripped.
Apr 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
GE Refrigerator Defrost heaters are shorted to ground.
I feel like you have defrost thermostat wired wrong , One side of heater should have nothing hooked to it but one side of thermostat, whitch should shut it off when it goes open.Now some G.E.s have the evaperator fan hooked to the same wire,so it won't run when thermostat is open.If thats the case someone might have wired it wrong causing a back feed.check that out that could be your problem.Someone could have wired a hot lead to it not knowing it was supposed to go dead when limit control opened.hope this helps. God bless. Fxit
Feb 24, 2008 | Refrigerators
Samsung Fridge side by side
It sounds like you have a defrost problem. This will either be the defrost heaters the defrost thermostat or defrost timer. In order to check the heater if you are competent enough you can check that you have resistance across the heater. Alternatively you can rotate the timer (normally in the fridge section abov the thermostat control) around to a defrost cycle (you will normally hear a click) and check to see if the defrost heater kicks in. Please note the cabinet has to be cold in order for the heaters to work. The defrost sensor should also have zero resistance across the terminals when the coil is cold. Please do no attempt the above unless you are practically skilled. A good fridge guy should be able to quickly identify the problem and remedy it. Defrost heaters are generally the first part to fail. Hope this is of some help.
Sep 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Freezer is working/refrigerator works sometimes
No No No. The most likely reason that the evaporator fan is not running is that it probably uses the heater circuit for its neutral feed. I.E. In order for the fan to have 230v/115v it needs a zero voltage brought back through the defrost heater and defrost stat. I know this for a fact because I just did one today and have fallen for this scenario (ie bad fan motor) before. You need to check from ground(earth) to each side of the fan motor (which is easily accessible) and then across the fan motor windings. The chances are that you have zero voltage across the motor. The fan will also not run until the temperature of the evaporator coil has been brought below 0 'C (32'F) and this can take up to 20 mins (again speaking from experience). This is to prevent snow being produced after defrost. I would advise getting the engineer to come back if you have paid him money and do a proper job. Shorts in Amanas can happen but have not come across one yet. Hope this helps.
Aug 26, 2007 | Amana ABB1927DE Bottom Freezer...
Maytag MFD2561HE Bottom Freezer French Door Refrigerator Logo
408 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
