We have a green stipe down one side of our plasma screen. Sony KE37XS910
  • 335 Answers
Thats an address registry problem that needs to be serviced. If its under warranty take it back.
Posted on Jul 18, 2009
Vertical black stripe on screen. how do we repair this.
The vertical stipe in the screen is the problem at the harizontal section of the board of your tv.Ethier the parts is leak like the capacitor.Try to replace the old capacitor with the same description or value of the parts.
Jul 04, 2011 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
May 05, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
6 blinks
trying to locate you to ask you if you found out the problem to your sony ke37xs910 plasma 6 blinks. i have the same tv with the same problem. does your tv set have sound but no picture.
May 05, 2010 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Want to know what color codes are on deh-p545W, looking for the speakes wire codes
What codes are you looking for ? Is that the speaker wire colors are grey/grey w/black stripe, white/white w/black stripe, purple/pruple w/black, green/green w/black stipe. The black stipe wires is the negative. If you don't have tags on the wires that say; LR,LF,RR,RF. There is another way to find which speaker wire goes where. First hook-up your Battery and Accessory and negative wires. Then just go in the unit and find the balance and fader control. Then just do one side at a time; like front left, rear left and so on....
Jun 04, 2009 | Car Audio & Video
Need a base stand for Sony KE37XS910 Plasma.
X-4042-206-3 is the part number.. only place i found it was at encompassparts.com.. your part is no longer available but this is the sub part..
Mar 14, 2009 | Sony Televison & Video
I got white vertical line running down a plasma display panel . they are close together that you cant even see on that side of the tv. on a closer inspection they are blue-green-red-blue-green-.... but...
A vertical line running down a plasma display can be caused by :
faulty buffer module.
Fauly sustain card.
Faulty plasma display.
Try unplugging power cable and see if this helps, if it does not , then you will need to call a technician.
In that case call the support number listed on your owner manual.
If warranty has expired, ask for a warranty extension, if available. this is cheaper than repair cost, and will cover the repair.
Jan 04, 2009 | Sony PFM-50C1 50 in. Plasma HDTV
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Sony KE37XS910
MODEL: KE37XS910, KE42XS910
SUBJECT: 9 Blinks of StandBy LED
CAUSE: Change the Switching Regulator part number 1-468-794-12.
Oct 29, 2007 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Vertical green line on screen
If your set is a plasma, this can be one of two problems : either there is a loose connection (one of many, many connections) between the plasma screen and the driver board, or one of the transistor devices has blown. Try GENTLY applying pressure to the opposite ends of the TV to give it a subtle "twist" (please be careful!). Sometimes moving the set to a different location will produce the same effect. If it's still under warranty, call your dealer. Vertical stripes are a common fault with plasma technology I'm afraid! :-( Next time, go for LCD!
Apr 09, 2007 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
