Question about Polaroid TLA-01911C TV
I have a Polaroid TLA-01911C. I switched from cable to air and did a scan, but no channels are found. I even hooked up an antenna with no channels found. Any suggestions?
  • Polaroid Master
  • 3,866 Answers
Ether the antenna is not good enough for the digital signals that are now brodacasted or you got a bad digtal tuner in this unit. i would buy a antenna from radioshack special for this TV.
Posted on Jul 18, 2009
Performed auto scan tried both air antenna witch is what I have and I also tried cable. Found no channels after each scan. the screen just says no signal
Check and replace its tuner. It is faulty.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 22, 2015 | Polaroid TLA-01911C TV
Auto scan does not detect any channels
Go into the menu on the remote control that came with your TV and set it to cable or antenna setting, depending on which one that you are using now.
Fix sound on Polaroid TLA-01911C TV
Audio amp may be blown. A cable may be bad.
What are you connected to?
Apr 04, 2014 | Polaroid TLA-01911C TV
Need a manual for Polaroid TLA-01911C
http://www.hdtvreview.com/Polaroid-TLA-01911C-hdtv.html
May 07, 2011 | Polaroid TLA-01911C TV
How to Chanel Scan
Tv is hook up to cable tv or free DTV air broadcasting?Have a good antenna source hook up or cable or satellite signals.Go into the tv menu go to SETUP.Go down to CH. press enter pick Cable or Air.Enter for scanning,after it done scanning will get all free DTV air or cable broadcasting channels stations signals.
Feb 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
My tv tla-01911c drowned on the flood. is there any solution to fix my tv
even if you dry it opening everything, the water might made the permanent damage already
my opinion is
NO you can NOT repair
Oct 01, 2009 | Polaroid TLA-01911C TV
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Need code
I called one-for-all and got a repair number and then sent the remote to them to have the codes added.
Dec 13, 2007 | One For All URC4220 Remote Control
Polaroid TLA-01911C TV Logo
467 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
