Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
The dishwasher won't drain completely - KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
    Problem Solver:
  • 10 Answers
Drain hose is either kinked, restricted, improperly routed or not high enough.
Most likely kinked.
Posted on Jul 18, 2009
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Dishwashers
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher started to wash then it stopped. Now there is water standing in the dishwasher and won't drain.
Hi
Daniel
Aug 22, 2011 | Kenmore 24 in. 16022 Built-in Dishwasher
Won't drain after rinse cycle.
Hi
Daniel
Aug 14, 2011 | Maytag Dishwasher
My 665 won't drain. Any idea what the issue is?
Hi
Daniel
Aug 09, 2011 | Dishwashers
My kenmore ultra dishwasher won't drain. how do i go about checking and repairing it?
Hi
Daniel
Aug 03, 2011 | Dishwashers
The dishwasher won't drain completely. Water is left standing in the bottom of the tub.
Hi
Daniel
Aug 02, 2011 | Dishwashers
Maytag dishwasher MDBH985AWS1 won't drain
Hi
Daniel
Jun 19, 2011 | Maytag Dishwasher
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
282 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
