Question about HP Pavilion dv2000t Notebook
What connections do i need to plug in my samsung lcd to my hp laptop?
  • 339 Answers
If your display has a VGA connector then you can directly connect it to the laptop. You'll need to use the F4 key to toggle between the external and/or built in displays.
If your Samsung is DVI only then you'll need a VGA to DVI converter something like this:
http://www.datapro.net/products/vga-to-dvi-d-analog-digital-convertor.html
If the issue is something different then let me know and I'll try to help further.
Posted on Jul 18, 2009
  • 22 Answers
Dvi or standard 9pin
Can't connect my HP G70-460 to my samsung tv
Have you selected PC or HDMI as your input source on the TV? Have you hit the FN Function Key on the laptop + the corresponding F1 thru F12 key that displays the image on the TV?
Press and Hold the FN key then hit the correct F1 thru F12 key that displays on the tv. The correct F1 thru F12 key will probably have LCD/CRT on it or it might have the icon of a display.
Apr 01, 2012 | HP Computers & Internet
My samsung lcd does not connect to laptop through vga cable
It the problem that it doesn't connect or that you can connect it but you get no display on your Samsung LCD? Assuming it's the latter, adjust your screen resolution down to 640 x 480 or 800 x 600 on your laptop. It's possible that your laptop resolution settings are too high for the LCD to interpret. Also, don't forget that you have to TELL the laptop to redirect it's video output to the LCD. There are usually three options on any laptop, 1. is laptop screen only, 2. is the external device (in your case the LCD), 3. is both the laptop and external device. These output is usually directed by pressing a function key (Fn) and a number key on the laptop. Look for the icon that shows two monitor screens with a ' as a separator.
Aug 13, 2011 | HP Compaq Presario V6000T Notebook
Why would my HP laptop screen go black?
A few reasons
1) backlight burnt out (or broken)
2) loose or broken cable AND backlight burnt out (or broken)
3) Failed GPU (probably integrated into the motherboard on that model)
4) failed motherboard (same issue above)
Check by plugging in an external monitor- if you get a signal, your LCD need a new backlight (or inverter, an easy fix under $15 USD)).
Cheapest solution is to simply replace the backlight, but you'll have to diassemble the entire laptop lid/cover AND the LCD to get to the backlight at the bottom. (this could be under $20 USD to do). Often similar sized LCD's with different part numbers will work fine in different laptops (meaning, a 14" LCD mady by samsung or LG will be compatible with almost any same 14" LCD made by either, especially if it comes WITH the inverter!)...
:D
Sep 04, 2010 | HP Pavilion dv2000t Notebook
I got a hp pavilion dv 3000 laptop and changed the lcd and video
Just plug an external monitor and conrm display is ok or not. If it is ok, you have connectted the back light or back light cable incorrectly.
Else mother board - back light connectivity is not there, check it
Jan 15, 2010 | HP Pavilion dv6000z Notebook
HP 2140 mini note does not recognize monitor.
Try pressing the Fn key and F2 key at the same time. Also make sure your tv is on the correct imput.
Jun 23, 2009 | HP Mini 2140 Notebook
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
Unable to connect to samsung tv as monitor for hp laptop
Hi there
DSUB is VGA, has your TV got a VGA port on the back? if so and you know what the source the channel is then you will need a male to male VGA lead and a mini stereo jack to left and right male phono jacks for the audio, the DSUB or VGA does not carry audio through it.
Good luck and thanks for using Fixya!!
Feb 12, 2009 | HP Pavilion dv2000t Notebook
Connecting Laptop to LCD
It might have something to do with wether the VGA cable has all pins connected.
I think some cables don't have all 15-pins wired.
As soon my LCD TV works I will post the outcome.
Greetz Arno
Nov 07, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HP Pavilion dv2000t Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
