Question about Bosch Axxis WTA 3510 Electric Dryer
I have an axxis not drying and code F:03 comes up
I have an axxis dryer and after a few minutes of drying code F:03 comes up. We have cleaned the lint box on the bottom left of the dryer, but it still feels like it isnt venting correctly. Do I need to open the back? Thanks.
    Problem Solver:
  • 10 Answers
Most likely your wall vent is restricted. Unhook dryer from wall vent and pull away from wall. If you don't get code your wall vent needs to be cleaned.
If unit still gives code sensor is either bad or theres a restrictions inside machine, likely in the blower wheel hosing. Air flow when running should be strong coming out of vent. many times strength of a blow dryer.
Posted on Jul 18, 2009
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis dryer isn't drying well
what is your model number is then we can get started then
Jan 31, 2013 | Bosch Axxis Condenser Dryer- White
Wte 86300US/05 dryer is not drying clothes shows f.03
This code indicates a problem with the dryer's heating system. The code will appear when the heating circuits are broken or when there is an intermittent break in the power source for the dryer. If the heating circuits are working and the power source is steady, you may need to replace the central control board.
Jan 09, 2012 | Bosch Axxis WTL 5410 Electric Dryer
WTE86300 Axxis beeps,displays"F-09" & shuts
Try taking off the back (middle) cap (torque screwdriver). On top of the heating element, you'll find a red (safety) button. Press till click sound.
That is all.
Happy Holidays
Dec 13, 2010 | Bosch Dryers
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
Dryer stops and bips - message F03
03 indicates as a rule that the alloted drain period has elapsed. Usually it is a pump failure or a blocked (or partially blocked) drain out system? You say you have cleaned out all the hoses and replaced the pump, well now it's best you just run a test to see how quickly the machine empties? In fact it should be less than 60 seconds and if it's slower than that I guess you've got a button or something blocking the drain outlet somewhere and acting as a gate valve no doubt.
The other thing you could check whilst your at it is the air chamber at the back of the tub. White clear plastic bottle above the motor, if that is gunged up you could get spurious error warnings like F03?
Feb 27, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
711 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
