Question about Maytag MDB9100A Dishwasher
Water is leaking into the dishwasher when it was not on. The water is really dirty and fills over time. How do I make it stop? It is not on automatic or on at all.
    President:
  • 1,136 Answers
Hi, The water is dirty, do you think it is water draing back into the d/w from the sink? You need to raise the dishwasher drain hose that hooks up to the sink. Make sure the highest point of the drain hose is over the connection where the drain hose hooks to.
If it was fresh water filling the dishwasher, the water would be clean.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 18, 2009
Testimonial: "I'll try that. Thanks"
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Jul 03, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
Doesn't clean dishes .I rinse dishes off before putting them in dishwasher.This is the 3rd time I have washed them and they are still really really dirty.I checked all the lines under my sink to see if...
water temp plays a big role in proper washing the temp coming into the machine has to be a minimum of 120 degrees.
next thing to check is proper water level,there should be standing water in the bottom of the dish washer when it has completed it filling cycle.
try and add some water with out over filling the machine once the fill cycle has stop then run it through again and see what happens.
the main wash motor may have to be replaced
Apr 09, 2010 | Dishwashers
It seems that not enough water gets into the washer.
The only thing that could really cause the dishwasher to not get enough water would be a dirty screen on your water valve, as dishwashers are strictly a "time fill", noramly 90 seconds fill time. Remove your water line underneath (shut off water first), remove teh brass elbow, and check screen
Mar 28, 2010 | Frigidaire Dishwashers
Dishwasher keeps tripping electric
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water in the dishwasher after the the cycle is complete
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Maytag MDB9100A Dishwasher Logo
278 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
