If the connections are tight and not loose, battery should not drain excessively. Gap in door should not drain batteries. Try gun wrapper over battery to improve connection if battery moves.
When the door is open, you will see some small cross head screws near where the hinges go into the door. These should be tight. If they are, then it could be the hinge failing. Try espares for a new set of hinges, but be warned you will have to take the entire oven out of its housing and both side panels off to get the the hinges.
Check the door seal size. Measure your door or doors, and take down the make and model number.
Ads by Google ';
for(i = 0; i '+ ''
+ google_ads[i].line1 + ' '
+ google_ads[i].line2 + ' ' + google_ads[i].line3 + ' ' +
'' + google_ads[i].visible_url + '';
s += "";
document.write(s);
return;
google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+9665908481+9016233241+8388126455+8941458308+8509902424+8509902424+9683278076+7122150828' + xchannels + gchans;
google_ad_client = "pub-9543332082073187";
google_ad_output = 'js';
google_ad_type = 'text';
google_feedback = 'on';
google_ad_region = "test";
google_ad_format = '250x250_as';
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
2Order a replacement door seal.
It's easy to find them online. Make sure to check the model number for
your refrigerator when you order it. When it arrives, hold the new door
seal up against the old door seal to compare the size. The sizes are
rarely incorrect, but it will save you the trouble of doing the job
twice if you happened to receive the wrong door seal.
3Locate the screws.
Lift the edges of the seal and find the screws underneath that are
holding in the plastic liner and door seal. Often, the screws hold in a
plastic liner, which in turn clamps the door seal to the door.
4Loosen the screws.
Begin to loosen the screws that hold in the door seal. DO NOT take the
screws all of the way out. It is unnecessary and will create more of a
job for you. If at all possible, loosen only a few screws at a time, as
you go.
5Remove the old seal.
Once all of the screws are loose, the door seal should easily slide out
from behind the plastic liner. Don't be too forceful when doing this
step, since some plastic liners can be quite brittle and crumble if you
are too rough. If the plastic is old, replace it.
6Insert the new seal.
Begin slipping the small lip of the new door seal behind the plastic
liner of the fridge. The best method is to start in the top corners and
work your way around the door.
7Tighten the screws.
Once the door seal is in a certain section, you can begin tightening
the screws. Begin with the 8 corner screws, and then check the
alignment of the door while closed. Also check that the seal is even
and straight. If the door is twisted, you can easily manipulate the
door to twist back into shape whilst the screws are loose. Then tighten
the remaining screws.
8Apply powder.
Use a bit of baby powder or talcum powder to prevent sticking. Rub some
powder around the hinge side corners of the door seal, and where the
seal slides. This will help to prevent the door seal from twisting as
it meets the metal of the fridge. If this still doesn't prevent
twisting, then wedge a screwdriver under the seal as you close the door
and leave it shut for an hour.
9Check for gaps.
Look for any gaps in the door seal, especially at the top on the
opening side. These can form due to the door dropping or being out of
alignment. One way to check is to turn on a flashlight and place it
inside, then close the door and look for light.
10Fix any gaps in the door seal.
Pack out the seal underneath the areas where the door seal has the
gaps. This can be done with a small strip of weather stripping, as
shown here, or a bit of tightly rolled up paper under the door seal.
Alternatively, you can heat the door seal up with a hair dryer to fix
the gaps. This softens the door seal and allows you to stretch it.
11Check the corners.
If the application of powder hasn't prevented the door seal twisting,
then wedge a screwdriver under the seal as you close the door and leave
it shut for an hour. The door seal will then have enough time to mould
into the correct shape.
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also. Eric
You need to bend the door, if the gap is at the top put your foot between the frig door and the bottom and push the door closed slightly. so you can check it and do a small amount at a time. till tou reach the point that the door closes tight. if the gap is at the bottom put a shoe or something about 4 to 5 inches wide. go for it you can fix this..... saw
Did you find someone that fix it?. I dropped mine today and there was a small plastic piece that helps to close the door, it broke, now the door won't close.
it sounds like your door switch is stuck. you can replace it yourself. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. remove the switch and replace it. hook up your wires. close the top and you should be good to go. good luck
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
I'm assuming you don't want to replace the door seal. Open the freezer
door. Stand "inside" the open door and place your foot at the right
bottom corner (looking from the inside). Place your hand in the top
right corner and pull it very slightly toward you. Do this in small
amounts until the gap closes making sure you don't open one at the
bottom.
An alternate method is to warm the gapped section of
the door seal with a hair dryer to soften the rubber enough to allow
the magnet within the rubber to pull the seal gap closed. This has
worked for me numerous times by making small adjustments at a time.
Good Luck
