Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
I need to adjust my vertical height on my Sony KV32HS500 on the DVI input. I don't recall the code to get into the service mode. All I can remember is "display, 5,) and either volume up or down... Any body recall the sequence? Thanks! Tom
  • 36 Answers
Press the following buttons on the remote commander within a
second of each other:
DISPLAY then Channel 5 then Sound Volume + then Power
I have the complete service manual,if you want the enitre service mode adjustments pages please request it at computec40@hotmail.com.
Posted on Sep 06, 2009
How can I adjust the height of the HP LP2465 24" LCD Monitor?
MOST OF THE TIME THEY WILL NOT ADJUST UP AND DOWN. LOOK FOR A SMALL LEVEL AT THE BOTTOM OF THE BASE OR JUST BEFORE THE BASE. I JUST GOOGLE IT AND FOUND PICTURE OF IT.
May 21, 2014 | HP LP2465 24" LCD Monitor
Adjust vertical height kg 55lh55
To adjust the height of the picture, you have to enter its service mode option, and should adjust the vertical amplitude data value, accordingly. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 24, 2014 | LG 55LH55 55 in. HDTV LCD TV
How do you adjust vertical height on sony bravia tv
Check the aspect ratio set. If it is set to wide, there will be black bars at top and bottom of the screen. Go to its picture setting menu, and adjust the settings. If it do not help you, enter its service mode to adjust the picture height. Although this is a semi-skilled work, if you have patience and concentration, you can do this adjustment. There is no need to open the TV. If you wish to get more details about how to enter service mode, and adjust the data values there, check the site linked here. http://electronicshelponline.blogspot.com/
Dec 04, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Bottom part of the screen cut off
If the vertical of the tv moves when it is that old that is your first warning sign. All electronics need their electrolytic capacitors replaced (especially the small ones). Not replacing them will cause a catastrophic failure. The next sign you will receive is when you have lines every half inch across your screen. Or the next sign will be losing your vertical entirely until all you have is a line. Then everything will go poof till only a standby power light will show. Pressing buttons in a secret pattern to get into the service mode will not fix failing.
Nov 27, 2013 | Televison & Video
Cant see the bottom of the tv screen
The vertical height of picture to your TV is more than normal now. When adjust the vertical height, the vertical lenearity also should be adjusted. There is no preset controls for this purpose in new generation televisions. You have to enter its service mode option and make data value adjustments. This is a skilled work, and only one who know better to adjust these values could rectify this fault. Entering in to its service mode, and adjusting data values there, without proper knowledge might make the TV irrepairable and irresposive to commands by both remote control and its front panel keyboard.
So it will be best for you to contact any experienced service technician to do this work.
Jul 09, 2012 | Sanyo Televison & Video
Magnavox color tv model no 20MT4405/17 vertical shrinking
Hello
Vertical shrinking means lack of height we thinks. If there is a height problem for philips tv, surely some of the philips electrolytic capacitors should be replaced. Most of the electrolytic capacitors made by philips shows either a slight leak or lack in capacity after some years or days after use. When replacing them make sure to select other brands of same capacity and voltage ratings. If this doesn't help, get into the service mode of that tv and adjust "VH" and "VLI" functions, if you knows the service mode code. If you don't know it, please get assistance of a technician.
Oct 15, 2010 | Philips Televison & Video
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
How do adjust verticle picture on Hitachi 46F510
You can adjust vertical height through the service menu, but i would recomed that you trouble shoot the vertical section as its probably a solder joint , leaky diode or something that is causing the problem. Often its bad solder at the vertical output IC itself that causes that sympton.
Apr 09, 2008 | Hitachi 46F510 46" Projection HDTV
Vert hight adjustment
How do I adjust the vertical hight of a SANYO 36" TV. vertical height can adjusted by height conrol that is inside tv in your case you can also adjust by remote control. for that you will have to open menu by giving service code. regards thanks
Sep 10, 2007 | Sanyo AVM-3659S 36" TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
