Question about Microwave Ovens
How do I clean the inside glass of microwave door ? There is a fixed splatter screen on it and it blocks access to the glass.Somehow,food splatter went through it.Appreciate any comments.
  • 491 Answers
PLACE A BOWL OF WATER IN AND LET THE STEAM DO THE WORK
Posted on Jul 18, 2009
I own a microwave: model # jes636wk01 There is a plastic film covering the wire mess on the inside of the door. Will the microwave operate safely if the film is damaged or removed?
yes. It is there to protect the glass from food splatters It is the panel with the million holes that controls the micro waves I would not remove it but have it replaced if damaged.
Jun 09, 2013 | Microwave Ovens
Food splatter behind screen on door of microwave
If you take the glass out you have to find a deaker or someone who the tools to check for leaks around the glass.
Mar 17, 2009 | GE JVM1640 Microwave Oven
Cleaning inside of microwave door
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 11, 2009 | Microwave Ovens
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
GLASS ON THE DOOR
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Aug 30, 2008 | Whirlpool MH1150XM Convection/Microwave...
Removed splatter shield
The parts can be ordered from the Panasonic authorized parts rep. You have to contact Panasonic for details.
I strongly recommend to have any work on a microwave oven done professionaly. There are radiation leakage issues if the door is not re-assembled properly. After doing any service the microwave oven must be tested for radiation leaks. I doubt that you have the radiation testing equipment to make sure that there are no leaks.
From US Food and Drug Administration (Microwave Oven Safety)
http://www.fda.gov/cdrh/consumer/microwave.html
Excellent Wikipedia Article About Microwave Ovens
http://en.wikipedia.org/wiki/Microwave_oven
Jerry G.
Jul 26, 2008 | Panasonic NN-S753 Microwave Oven
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dirty Door Glass inside the choke - how do I clean it?
Its very hard to take apart the doors They normally have a lot of screws. May have a plastic snap on cover that's covering them up. Some of them are even sealed and can not be taken apart.
Anytime you work on a door you must check it with a microwave leakage meter. The door has metal gaskets and a screen that blocks the microwaves upsetting them will cause it to leak.
This is not a do it yourself repair.
Dec 24, 2007 | GE JVM1870 Microwave Oven
I am currently fixing my microwave, which has done the same thing. Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60AMicrowave
just select your brand and under parts, select doors and handles. It will be called Door film, peel & stick. For my microwave, it runs from $16.00 to $21.00. Seems like a very easy fix.
Nov 09, 2007 | Microwave Ovens
Microwave Ovens Logo
735 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
