I need a remote for a jet air heat pump. Can I
I need a remote for a jet air heat pump. Can I use it manually without the remote?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
You can use it manually. If you need a remote, NEC and Hisense/Kelon units use the same remote. If you live in Australia, your best bet is to contact NEC. Their website is www.nec.com.au
Mat
Posted on Jul 18, 2009
Jet not running & spa not heating.
check to see if recirculation pump is running that one heats spa
Jan 25, 2016 | Pool & Spa
Blocked tv without remote. how to unblock
You DON'T! You need to buy either a replacement or get a universal remote from Best Buy.
Jan 19, 2014 | Air Con 18,000 BTU 13 SEER Mini Split...
Will not idle without choke
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
05 yz450f wont idle must run by friday YZ 400 426 450
Wont run without the choke yz450f 03
YAMAHA YZ450F Owner Service Manual
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-11_784.pdf
Jul 21, 2013 | Yamaha YZ 450 F Motorcycles
My Apollo hot tub stopped heating and the first set of jets are not working and both seemed to have gone out at the same time. The second set of jets and the air are fine. Does anyone have any ideas of...
You're pump #1 has failed. Your spa has 2 water pumps and an air pump. Number 1 pump pushes water through the heater. Pump 2 simply supplies the second set of jets with water. The air pump simply pushes air through the air jets.
If pump one fails you will have no heat and the first set of jets will not turn on. Pump 1 is the most prone to failure because it kicks on any time the spa needs to filter or heat. This happens automatically every day so pump 1 works much harder than pump 2. Your heater has a safety mechanism that makes sure that water is flowing through the heater when it kicks on. If there is a problem with pump 1 your heater will not kick on. There are stickers on your #1 pump. Get the model number off of the sticker and order a replacement pump from a web site like www.spapartsdepot.com. If you give them the model number of the pump they can send you a replacement. I'm 100% sure that's the problem. I'm not affiliated in any way with the web site I mentioned but I'm pretty sure they will have the pump you need. Good luck!
Mar 24, 2013 | Apollo Pool & Spa
2005 yz250f header pipe getting red hot and will not idle without choke on
Dirt Rider Magazine
YZ250F won idle without choke solved Intake Jetting Fuel Injection
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Dec 05, 2012 | 2005 Yamaha yZ 250
2001 Shadow Sabre, Won't idle with choke off unless giving it some throttle.
Hi, Rickgilbreat and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Starts but won stay running unless with choke Discussion
Won idle without choke
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Aug 23, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
How to use mitsubishi heat pump remote
i have a mitsibishi heat pump which i purchased 2years ago but have missed place the instruction manual are you able to help me with this. the problem i am having is setting the right temperature and function that i need.the model is msz-ge5ova, thank you
Jun 02, 2012 | Mitsubishi MSZ09UN Air Conditioner
Yamaha royal star xvz 1300 won't idle without choke
2003 Star 1100 Custom won idle without choke aftermarket exhaust
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
https://www.tradebit.com/filedetail.php/243740175-1996-2001-yamaha-royal-star-xvz13a-service-manual
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Jan 01, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
1992 Honda CB 750 Nighthawk will not idle without choke
Hi, Emeraldcp and the usual suspects are:
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike won Run without Choke
Honda Nighthawk CB 750 1991 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Sep 26, 2010 | 1992 Honda CB 750 Nighthawk
Heater won't go on my jucuzzi model 315
upper spa side control should have a heat lite, if on then heater is recieving voltage. Sometimes pump can have an air bubble in line.
Make sure water is flowing from jet. Spa will not lite heater without water flow. If no water try loosing union after pump to pull air through, so pump can fill with water, and no longer cavitate. Kirk
Feb 15, 2009 | Jacuzzi Pool & Spa
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
