Question about Sony MDS-JE480 Mini Disc Player
HOW TAKE OUT OF
WHEN I INTRO THE MD AND THE SCREEN SHOW "DIN UNLOCK' HOW I TAKE OUT?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Posted on Jul 19, 2009
Din unlock c71
the input source you have selected is not working. If digital it might be a copy guarded source which the deck cannot read...
If you get fancier and are trying to record the optical output from a newer device like a 5.1 or 7.1 receiver although the signal will go through the MD deck cannot decode the advanced optical signal. There are adaptor boxes on eBay which decode 5.1 & 7.1 optical signals to an optical signal the older MD can read and record from.
Try selecting another source like analog RCA. The digital stuff I mentioned applies to digital RCA and Optical Cables like toslink.
Feb 08, 2014 | Sony MDS-JE520 Mini Disc Player
Jd520 error read c71
DIN unlock is related to a digital clock being missing so the unit is looking for a digital input of some kind. Since your laptop is putting out analog change the MD input to analog and of course use the correct inputs. A 1/8" or 3.5mm audio cable may fit into an optical port but it will never work in that way.
Nov 14, 2012 | Sony MDS-JE520 Mini Disc Player
Need to unlock din lock
By 'Unlock din', do you mean unlock the region the recorder uses, unlock the din input or unlock the tray or what?
When recording and you see 'unlocked', it means the DIGITAL signal you are trying to record is unclear or missing.
If you are trying to record a signal from another region disc, it will not copy. Add a little detail.
Feb 21, 2012 | Pioneer PD-R609 CD Recorder
Din unlock? how do i get rid of it ?
Several problems here,
Overall the deck is not getting a signal from the input, so you need your input selector set to one which is active...
However, in some cases a copyguard system will prevent your recording from a second generation digital copy and depending on your deck give the DIN unlock statement.
In other rare instances the deck cannot handle the conversion rate from a DAT, in others if your are trying to record from a Dolby Surround sound source on an optical input, the older MD deck cannot decode Dolby 5.1 or 7.1 even when it is getting the digital signal, in that instance you need to get a digital convesion box on ebay which kicks down the 5.1 or 7.1 dolby to something the older MD deck can understand even though it is getting the optical signal.
I hope I addressed all of the options...
Jun 27, 2011 | Sony MDS-JE520 Mini Disc Player
Got error message din unlock c71
You probably have selected an recording input which was not connected to a source, you may have a cracked optical cable, on some other machines the digital copy management system gives this error from an attempt to record a third generation digital copy. You also may have a digital source such as Dolby 5.1 or 7.1 the older MD deck cannot read in that event you would need to get digital conversion box to kick down 5,1 or 7.1 to something the deck can undestand. If you were recording from a TV some allow you to reset the audio output to something the deck can understand from Dolby 5.1 etc.
Jun 02, 2011 | Sony Audio Players & Recorders
Din Unlock - Unable to record
You must have the unit switched to "DIGITAL" input - switch it to "ANALOG" and record that way. The "DIN UNLOCK" is when you have the lack of a proper digital signal, or a digital signal with copy protection, like you cannot make a digital copy of a digital Minidisc, etc...Does that make sense? Let me know if the "Analog" setting works for you. Good luck.
Nov 07, 2009 | Sony MDS-JE330 Mini Disc Player
I have a minidisc model mds e10
it seems your MD unit is expecting a digital signal on the digital input causing this message to appear.
You need to connect a signal source to the digital input
or
connect an analog signal to an analog input and select the analog input as signal source.
In both cases the DIN UNLOCK message will then disappear.
Cheers
May 14, 2009 | Sony MDS-E10 Mini Disc Player
Computer won't go pass intro screen
ok
when u power up the laptop press "del"or F2 or F5 to enter in bios .then load optimal defaults settings.then save and exit.
then check.
Jan 19, 2009 | Toshiba Satellite M45-S359 Notebook
Skip intro button action script
Dear nic_hk, in macromedia there is an option of removing the intro by checking the skip this box or by checking the box that says 'dont show me this screen again'
About flash action script this is a complete resource for learning it along with embedded java scripting.
If that has helped you please press 'fixya'
Nov 27, 2007 | Adobe Photoshop 7.0 for PC
White Screen
  • you need a new screen and a service manual to repair once you get one send me a copy buddy
Nov 11, 2006 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Sony MDS-JE480 Mini Disc Player Logo
145 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
