Question about Cuisinart DLC-5 Food Processor
Slicing Disk Stem Stuck on Cuisinart DLC-5 Food Processor.
Our Cuisinart DLC-5 is 3.5 years old. Suddenly the slicing disk is stuck inside the bowl. The stem of the slicing disk is cracked. I tried various tools to try to pry the stem off the plastic cover on the metal motor shaft and also tried to pry the disc up. But I was afraid I'd break the bowl if I used too much force. I called Cuisinart today. The customer service I spoke to said the plastic cover on the metal motor shaft may also be cracked. He couldn't give me a way to get the plastic cover off the metal motor shaft. He said I might have to send the food processor to Cuisinart for service, but couldn't give me an estimate of repair cost.
5 Suggested Answers
SOURCE: Install Cuisinart stem cover
I was able to replace my pieces thru Small appliance.com I ordered new parts and the directions on how to remove the old stem and put the new one on.
Put a little vaseline in the rim of the new stem. Use a wooden block and a hammer or rubber mallet and lightly tap the new one into place.
Cuisinart called two weeks after the fact to say I have to send them the machine.....
Posted on Apr 06, 2008
SOURCE: Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Posted on Jul 14, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
  • 3 Answers
SOURCE: cuisinart DLC-8 Plus Motor Shaft Cover broken.
Check the thrift shops,flea markets and yard sales. I found a work bowl for $3.50 at Habitat for Humanity store...looks like new.
Boy, now that I know....if I see a cheapy at yard sale etc I will pick up a spare! I love my DLC 8 Plus.
Posted on Feb 12, 2011
How do I attach the slicing blade to my cuisinart food processor
Slide the button down on the white stem. Place the blade on the stem, and turn the blade a few degrees and the button should click into place.
Jun 27, 2010 | Food Processors
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Lid stuck on bowl of my Cuisinart Mini Prep Plus.
Generally they twist off, but on the DLC-2, if the lid won't come off, a replacement bowl and lid is around $18.00
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Cuisinat DLC 8 Plus Bowl won't unlock
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Slicing raw potatoes
I read the manual online. Thanks for your response.
Nov 09, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart DLC-5 Food Processor Logo
201 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
