How can I repair when gasoline was used instead of mixed oil/gas?
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
this is what happens when someone run straight gas in two cycle engine
Fixing seized up echo weed eater
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Testimonial: "Kudos to L Pfaff for a superb advice. The above mentioned posts/tips were additionally very helpful in recognizing the problem and the options/remedies and simple steps to unseize the machine. I am extremely grateful for sharing your expertise. BTW, I flatly rejected Sears Repair center to charge me $55.00 simply to "take a look" at the blower. It was not customer-friendly at all. Thanks once again for this wonderful "first time" encounter with experts like you from FIXYA.com. 3 cheers!!!"
