Question about Fisher and Paykel GWL11 Top Load Washer
My smart drive 701 is desperately trying to fill - takes over an hour, it never seems to fill and will not wash. How do I fix this
    Scholar:
  • 84 Answers
Try checking water hoses going to the unit. Make sure they are not kinked. Shut the water valves off and disconnect the hose and check the inlet ports on the unit. Check to see if you have some kind of blockage.
Posted on Jul 26, 2009
    Problem Solver:
  • 17 Answers
Easy thing to try is clearing the screen filter in the hose
Posted on Jul 20, 2009
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
701 smart drive washing machine leaking but working no error
is the leaking water brown if so with it being noisier on spin it will prob be the drum bearing are on there way out
May 28, 2012 | Fisher and Paykel Washing Machines
The smart drive 708 on any wash cycles has poor water flow..ie the water seems to be filling up very slowly and the normal wash cycle takes 2hrs
Hi Challe340, Sounds like your machines Inlet solinoid valve that supplys water to your machine may have a clogged internal diaphagm, its quite normal for it to clogg up due to high sediment build up in the water mains over the years and seeing that the machine is a smart drive 708 it probly hasnt had inlet replacement in it entire life. As for the normal wash cycle taking so long could be due to restriction in water flow from the faulty inlet valve slowing down the water fill segments in its rinsing cycle stage, hope this help.
May 01, 2011 | Washing Machines
Fysher and Paykel smart drive 051. takes ages to start. cold water flow seems ok. takes 2-3 times longer for full cycle. sometimes stops and hot water light flashes. yours, jagrat.
Hi just read your posting.Now what water temp have you selected for wash?Is it cold, warm, or hot?Sounds like a water flow problem to me.The water valves on your model of machine sometimes sound like they are filling correctly but they only let a little bit of water in.How long does it take to fill your machine and start agitating when you have selected low water level?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 18, 2010 | Fisher and Paykel Washing Machines
Fisher & paykel 501 smart drive washing machine
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
Jul 05, 2010 | Washing Machines
Intuitive Eco 701 ... error code 50. I'm sure it's to do with the fill solenoids. It is filling very slowly.
Yes. Whichever is filling slow. Hot or cold. It is a code for the fill valve. Just replaced the cold fill valve on my unit which seems to be the one that most commonly goes out. Easy repair. 2 screws and 1 Plug...If you unscrew the top by taking out two phillips screws in the back, you will find some paperwork about trouble codes, repairs etc...Right next to the fill valves.
Jan 24, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
May 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
F&p washing machine
Replace the dual inlet water valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
273 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
