Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
"wrong disc" message even when playing DVD which were watched on this machine before. I...
(More)
"wrong disc" message even when playing DVD which were watched on this machine before. I already used CD disc cleaner and kept machine on for 2 hours without disc inside the machine as per technical support from Coby.
When I put a dvd in the player, "wrong disc" comes up. I have tried many differnt dvds...
(More)
When I put a dvd in the player, "wrong disc" comes up. I have tried many differnt dvds which work on other players. I can hear it going around, It says "loading "for a while then" wrong disc." The screen comes up when it is turned on. The player is plugged in. The set up works also. All is on the default settings. Thank you
