Dryers Logo
Marvel Mccloud Posted on Jul 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you take out heating element in a maytag neptune dryer
andrew petersimes
Level 2:
Sergeant:
  • Expert 248 Answers
  • Posted on Jul 12, 2016
andrew petersimes
Expert
Level 2:
Sergeant:
Answers
248
Questions
0
Helped
91306
Points
921
My Maytag Neptune Dryer heating but not hot.
check the filter are clean
or stats may be faulty
2answers
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
1helpful
Maytag neptune dryer not geting hot
If your Dryer is the Electric version, then more than likely you have a burned out heating element, you can check it by first UNPLUGGING THE DRYER!!! after you have UNPLUGGED THE DRYER!!!, you can remove the front cover and check the element for continuity, the whole unit comes out as a Tube.
Maytag Neptune Not heating
I did find a service manual for this unit. If you want to get me an email address to send it to it is in pdf format.
Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Blows only cold air
Check connection to heating elements. My have bad heating elements
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
