Question about Garden
My stihl weedeater's head is hard to turn - Garden
  • 50 Answers
Needs grease inside the shaft
Posted on Oct 16, 2009
Does a stihl weedeaters have primary & secondary windings in their coils ?
which model.?? I have all the parts manuals so will gladly help with a little more info
Apr 22, 2016 | Stihl Garden
Weedeater head spins off the weedeater body
Jacque It's possible that you are not tightening the head on properly or the nut has completely sheared. If you can get some two part resin glue i would suggest that you try and stick it back with this. I used it on a Mculloch and it lasted years. Make sure to give it 24 hours to set and that everything is clean.
Sep 03, 2013 | Stihl FS 85 Weed Eater
Stihl fs44 weedeater wont fire
Do you have compression, a good spark and is fuel going into the cylinder.? Working on a solution.
Jul 27, 2012 | Stihl Garden
Stihl sf44 weedeater wont fire
more info please? does it now have a spark and good compression?
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
Mar 17, 2012 | Weedeater Garden
How to get the head off of a Stihl weedeater. Model FS 45
There is a hole beside the angle gearbox, stick an awl or small screwdriver into it & turn the head until it 'locks'. Then rotate the head clockwise until it comes off.
Jul 29, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
What needs to be done to remove the head off of a stihl weedeater?
If you are talking about the spool and string area, remember that Stihl have left hand threads so you turn it the opposite of lefty, loosy, righty tighty. There is a small hole in the side of the head to insert a special tool that came with the weedtrimmer when you purchased it. If the tool isn't available use a small phillips or flathead screw driver to hold the gear box still while unscrewing the head counterclockwise.
Jun 14, 2009 | Garden
Garden Logo
538 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
