Question about Westinghouse LTV-27w7 7 in. LCD HDTV
32" LCD TV white color goes green after 15 minutes
I have the same problem. After 15 minutes, the white color statrts to flicker and turn lime-green and slowly over 5 minutes goes completely green. Everything works 100% prefect however. All other colors are perfect and operational, TV works, just the white colors have gone green. Sometimes, the TV kicks out of this all of a sudden and starts showing normal colors for a while, then kicks back into white = green mode.
Happens with both VGA and DVD inputs.
3 Suggested Answers
  • 92 Answers
SOURCE: Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Posted on Dec 04, 2009
alpug
  • 1961 Answers
SOURCE: I have an older Westinghouse
examine the power supply of your tv a defective/bulge capacitors can cause this problem replace it with the same value.you can easily identify a defective capacitor they appear bulging deformed and melting.you have to open the back cover of your tv to access the power supply this is were the power cord is connected.thanks and please post a message if you have further question..if my solution solve your problem please do click the thumbs up button for my rating..
Posted on Sep 07, 2010
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
My dell E207WFP lcd first flickers and then flashes red,green, blue, black, white and green color after some time of use ...
some of the capacitors are blown on the boards that are inside the unit
the lcd is on its way out. I recomend when getting a new one to turn it off whenever you are not at your pc. even though it goes to sleep after a while of no activity there is still a current going through the unit because if you move the mouse it will wake up. I know this because I was a bench technician and I have done board level repairs. These capacitors have anywhere from a 20000 to 40000 hour life span so when not at your pc turn it off!
Nov 23, 2012 | Dell E207WFP 20" Widescreen Flat Panel LCD...
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
Sep 09, 2009 | Samsung Televison & Video
Sep 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Mintek dtv 323-d
my 323 lcd has power sound and plays dvds but i cannot see a picture
Jan 21, 2008 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Soyo 32" LCD flat panel
Better to send it back before the warranty expires, the set has issues
Oct 21, 2006 | Soyo DYLT032D 32 in. LCD Television
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
251 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
